Paddock stand use
Discussion in 'General 1000RR Discussion' started by CBRGav, Mar 1, 2019.
  1. CBRGav
    CBRGav Active Member
    Saw this on YouTube and had to ask, is this a safe way to use these paddock stands? I always use mine the other way under the spindle not on the caliper like that.
  2. nigelrb
    Looks safe - but I wouldn't do it.
  3. CBRGav
    That was my thinking, wasn't sure if I'd been using them wrong my whole life:confused:
  4. lardytkd
    lardytkd Active Member
    It is totally safe to use paddock stands like this. But the only time I ever use mine in that way is when I'm taking the from wheel off. Coz if you put them on the spindle, wheel ain't coming off, lol.
  5. nigelrb
    Huh? It is.:)
    I did exactly that when I recent did my tyre change; Ryde stand directly under the bottom of the forks. The spindle is not affected by the stand. (referring to 2011 RRB)
  6. Stuish
    Stuish Senior Member
    They are designed to go under the forks for a reason, surely. It might work but I wouldn't trust it.
  7. CBRGav
    Mine go with one arm under the spindle and one on the back of the fork, just curious if anyone else used them this way, first time I've seen it this way
  8. Jsm
    Jsm New Member
    Yep always use them this way
  9. CBRGav
    So from what I can gather it works but it's not a common use, glad I've not been using them wrong all the time:D
  10. PauloHRC
    I have used mine in this way before, though I tend to use it under the spindles. In a way it is actually more secure, ive experienced the cups (or whatever) flip out from under the fork spindles. I've never thought it was a great design. I prefer the ones that lift the head stock.
  11. zxrob
    zxrob Active Member
    Whats more concerning is the guys bike has blue fork bottoms and red calipers:eek:
    Rob
  12. nigelrb
    Probably American. Maybe even by default like @Spygoat :D.
  13. Spygoat
    Spygoat Well-Known Member
    We lay no claim to this man or his choice of colors.
    I have never used my stand like that either.
  14. Selmer50mark
    Personally I prefer a head stock stand , forks can be removed with these 20180415_163531.jpg
  15. nigelrb
    I have to agree that these are very simple and stable to use. I inherited a Constands one recently, but need to buy pins to suit the Honda. Do you recall, or can you check the pin size for the RR6? It seems to be different from the later models.
  16. CBRGav
    I've already got stands was more curious about where he positioned the arms, came up on YouTube and I thought it looked odd
  17. Muffking
    Or pin type under forks.
  18. Muffking
    Or Spider stands for the garage.
  19. Muffking
    13mm ;)
  20. Selmer50mark
    @nigelrb yep 13 mm pin @Muffking got there before me ;)
