CBR1000RR 2009 top speed
Discussion in 'General 1000RR Discussion' started by Gixxa84, May 18, 2019.
  1. Gixxa84
    Gixxa84 Active Member
    i know it’s petty but is the 2009 top speed limited by honda?
  2. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
  3. nigelrb
    As above, the short answer is no.
    But top speed will be affected by the sprocket ratios you're using. Nevertheless, the rev limiter will still cut you at 12,000 or thereabouts, by which time you're probably doing 175 mph in standard gearing.
