Optimate 4 SAE Fitting
Discussion in 'Mods, Upgrades, Accessories and Products' started by DazK, Jun 7, 2019.
  1. DazK
    DazK Active Member
    I’m chasing up a fitting for my optimate 4. I have the permanent female fitting on my battery (white, one square one semi rounded) and looking to put a usb power point to charge my drift and go pro but need the adaptor for the SAE fitting. Does anyone know the part number or had/got one? It’s not going to be a permanent USB fitting just plug in as and when needed.
  2. nigelrb
  3. hitch
    hitch Elite Member
    • Optimistic Optimistic x 1
  4. DazK
    DazK Active Member
  5. DazK
    DazK Active Member
  6. bonjo
    that's a good link hitch. You can also buy the TM/ Tamya connectors individually: GZ98 or GZ99
    those connector are crimped so you should be ok.
    You can of course solder them if you prefer
