Tank badge removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by ninjagogo, Jun 29, 2019.
  1. ninjagogo
    ninjagogo New Member
    So i have chinese plastics on my bike but as @nigelrb pointed out the badges on the tank have the 'wing' pointing in the wrong direction, anyone have any idea how to remove them from the circular recess on the tank plastic so i can swap sides with them
    • Downvote Downvote x 1
  2. nigelrb
    Huh?
    Anyway. I have done a change over of OEM badges and found that gently prising them out with a not too sharp kitchen knife removed them easily. They're stuck with only a thin perimeter bead of bonding. (It's only one side you have to do as I recall?)
  3. Boothman
    Some one previously suggested fishing line, but I don’t think it was on the forum - might have been YouTube
    #3 Boothman, Jun 29, 2019
  4. Barstewardsquad
    Dental floss works on windcreen mounted stuff like dashcams.
  5. nigelrb
    Fishing line might work on a flush mount badge/fitting, but remember - these badges are recessed, so you'd have to get a fair hunk prised off before you could get the line under. This isn't just my opinion; I have it on authority from:
  6. ninjagogo
    Cheers I’ll give that a try with a bit of cloth between the tank and knife. I thought it was just the one side but it looks like the badges are both wrong so just going to swap sides with them hopefully
  7. nigelrb
    Maybe no one else would notice?:D:D:D;)
  8. ninjagogo
    Haha it’s too late now my OCD has kicked into overdrive
  9. raphael
    I used a hairdryer and a knife to just raise the badge enough to get under the edge and easy after that
  10. ninjagogo
    Good call with the hairdryer, was you able to re-use the badges or am I being too optimistic there
  11. raphael
    Yes mate I could re use them, just have have to get the back clean then a little silicone to re stick
