2017-2019 wheels
Discussion in 'General 1000RR Discussion' started by nozdog, Sep 7, 2019.
  1. nozdog
    nozdog Active Member
    Hi All, just to ask will the wheel off a standard 17-19 fireblade fit a 2011 fireblade with the right spacers?
    also the wheels come with discs front and back but I do have a set off a 2011 if I need to change them.
  2. nigelrb
    Can't give a definitive answer, but the 2017+ rear axle nut is larger which suggests a thicker axle and therefore changeover bearings might be required.
  3. nozdog
    Cheers Nigel I’ll have a look on parts list see if I can see a difference :)
