Honda CBR1000rr 2012 Track Bike Breaking
Discussion in 'Parts, Accessories & Clothing' started by vic_ster51, Oct 25, 2019.
  1. vic_ster51
    vic_ster51 Active Member
    Breaking my 2012 honda cbr1000rr track bike. I built from my road bike using a track frame. Bike is cleaner than new. Everything brand new. Every bolt is titanium. Its done 2 miles down the road thats it. Everything is mint or near mint condition.
    Lots trick parts. All fixings titanium and all suited perfectly for the bike. Nice tapered heads for certain bolts etc where should be. Things like that.
    Engine never been raced. Came out of my perfect running 12 bike with 12k miles on it. Just had all new seals fitted, Paper side case gaskets, water pump, thermostat, drain bolt washer etc etc. Repsol race oil. All honda oem parts used - oil filter, plugs etc Can provide receipts of these parts from honda too. Titanium bolts - sump, engine case's, gold rocker bolts, water pump, thermostat, block off cover bolts (ken take plates) Oil drain, exhaust studs and nuts. Runs perfect, standard engine. can be heard running and ridden at the moment. Have dyno printout aswell super smooth curve 171bhp ecu reflashed woolich
    Few trick parts on it are -
    magical racing (japan) full race fairings
    Ohlins TTX GP rear shock (bought from germany, tuned specially for the blade by experts place there)
    Translogic IS4 q/s As new sensor aswell push and pull (500 road miles)
    Full race samco blue hoses
    Brembo corsa corta MC with ti hardware
    Front forks with ohlins piston kit
    Brembo front brake pads SC 2 road miles on
    Brand new SES front clock bracket and bottle holder
    Full UK lockset 2 keys all locks etc woolwich flashed ecu - lowered rad fan temp kickin (if you run fans) O2 sensor delete, exhaust servo delete, fuel cut disabled etc
    A-tech carbon swingarm chain guard lower (japan part)
    TWM brand new clutch perch and adjustable lever to match the brembo brake
    Brand new silver Harris 50mm clipons with slight rise to suit blade
    Brembo T drive front discs
    As new GB racing covers
    Full Akrapovic exhaust system from 2017 bike
    Padgets silver rearsets hrc style
    BMC Race Airfilter
    Plus more & all the other normal parts.
    I also need few 12+ standard parts so can do a swap deal aswell, headlight etc
    cant upload all the pics as too big
    70392823_2128941770747052_8766849526192406528_n.jpg 70598402_2128941707413725_1914977869763706880_n.jpg 70895060_2128941754080387_746733124435574784_n.jpg IMG_6011.jpg IMG_6012.jpg IMG_6014.jpg IMG_6551.jpg 71218435_2128941670747062_2299587376462168064_n.jpg 71218435_2128941670747062_2299587376462168064_n.jpg IMG_6013.jpg
  2. Boothman
    Why breaking and not just selling as a full bike - or am I missing something (I usually do)
  3. vic_ster51
    Pain in the ass selling whole bike, plus soon as mention track bike price goes down and there is like a million for sale. Id get more in parts i think.
    Plus bits left i will use myself for a road bike etc
  4. Boothman
    Yep I was missing something :(
  5. Gabtiel2202
    Gabtiel2202 New Member
    I'm intrigued - what are the bottles at the front of the bike for?
    Also how much are you after for the GB Covers and for the Translogic QS mate?
    Thanks
  6. vic_ster51
    Bottles are fluid holders, expansion tank etc. 1 i have for that the other is tank breather. These are sold though
    These covers are sold also. But i have another set in used condition for £70 posted
    QS is £315 posted
  7. David Acton
    David Acton New Member
    Do you have any 08-14 headers.
  8. vic_ster51
    Standard headers? if so, got a very nice set, £55 posted a less nice set - £40 might be able to deliver on sunday depending where abouts you are in uk, as im delivering some parts
  9. David Acton
    Can you pm a picture of the good one.
  10. vic_ster51
    Can't send pics in pm. I don't think
    Send me your number or email please
  11. Trackit
    Trackit Active Member
    I am in the process of fitting a HRC subframe to my 2015 blade for track use, do you have the undertray you used to house the fuse box and regulator? Would you be intrested in selling just the front fairing and belly pan?
  12. vic_ster51
    The battery tray won't fit this hrc subframe. Well you have to cut it alot etc so you'd be better looking for a damaged one bit as such so it's cheaper
    I would sell the front and belly pan. Ideally pickup as they a pain to post
    I'm in Norwich
    The fairings are new. I just prepped them abit and spray painted matte black. Just need bit more prep and few more coats and they done. Mint condition and they from magical racing in Japan if you google it you will see. Also there huge price. But the mounting holes like oem quality too and line up great
    I want £300 for front and pan.comes with screen and brackets
  13. vic_ster51
  14. Gabtiel2202
    Ah right, that makes sense... I was thinking it some crazy meth injection system!
    Thanks for the reply on the covers, I'm looking for a fairly fresh set so will pass on the used set but thanks anyway.
  15. decfoley
    decfoley Active Member
    Hi mate
    Price for front and rear carbon hugs and chain adjusters?
  16. vic_ster51
    All these you wanted i am keeping now i'm afraid, sorry. They are carbon wrapped. CRC sell the front mudguard in that style
