Gear shaft support
Discussion in 'Mods, Upgrades, Accessories and Products' started by mk3golfcab, Nov 26, 2019.
  1. bonjo
    I’ll make some popcorn while waiting.
    Must say nigel s got a point. If the shaft has play then there could be a prob inside where the xtra support helps
    A quick shifter would only dip the rpm
  2. dern
    dern Well-Known Member
    I fitted a Gilles ones about two and a half years ago after having the bike for a year. Firmed up the gear changes no end and don't regret buying it at all.
    • Agree Agree x 3
  3. Dave dunlop
    Dave dunlop Elite Member
    Yep had a Gilles fitted on my 14 plate... Echo above comment with it feeling more of a precise and direct feel, It certainly felt improved on up and downshifts...Highly recommended :)
  4. mk3golfcab
    mk3golfcab Elite Member
    Aww you buggers! Looks like I’m going to have to get one before me postman stops for Xmas. Can’t believe you lot making me part with my money so easily!
  5. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
  6. Jez
    So the bike has come into the workshop today. I have pre made some mods.
    But the technical measurements took a nose dive when I grabbed the end of the gear lever and pulled it up and down. It does rattle
    now the gear lever DU bushes have been changed for needle roller bearings.
    I did make it like the aftermarket type needle roller bearing going straight onto the gear lever shaft but I did not like the wear marks on the shaft ( shown in the picture ) so I have fitted a larger needle bearing and a hardened sleeve to fit on the gear shaft.
    Now there is no play in the shaft
  7. mk3golfcab
    Racetorx have got a 20% off sale today and tomorrow :)
    happy xmas
  8. F1CT1C10U5
    Finally got mine installed.
    Now, it's testing time!
  9. Jamie_lee
    Jamie_lee Active Member
    I have a H&M quickshifter with Honda gear indicator, still get the odd neutral shift. @mk3golfcab it is annoying lol!
  10. F1CT1C10U5
    I have to say it did nothing I was expecting it to do.
    Altho the shaft has now 0 "wiggle", gears still feel clunky.
    Also, I did experience a false neutral the other day, using quickshift.
    • Useful Useful x 2
  11. Jez
    I can say the needle roller bearings on the gear lever have made a big difference, I would say more than the support, This year it has been so much better
  12. Gravel trap
    Gravel trap Senior Member
    I think I'm going for one of these on my rr4 . the gear change is worst feature of the bike.
  13. Jez
    I put needle rollers in the gear lever as well as the output shaft support, It takes a bit of doing but well worth it
