  1. LRJimmy
    LRJimmy Active Member
    Then it became too good to use as a Winter hack...:rolleyes:;)
    • Agree Agree x 3
  2. Selmer50mark
    Nothing for weeks o_O let's see what Santa fetches tomorrow ;)
  3. Nigel H
    Nigel H Active Member
    It's still slowly coming to pieces at the front. I had forgotten what a pain access to the plugs is.
    The module is in the tail as they do dire warnings about heat but I haven't even got the air box out yet to hit the plug wiring problems.
    All advice very welcome.
    I took a break to get out some webbing and the leather-working tools to sew up a battery lift strap.
    I've been promising myself that for ages. It's made it a bit tighter but getting it out is now easy.
  4. Stuish
    Stuish Senior Member
    Even if you did find a beaten up rusty 125 you would get the harpic out and return it to new ;)
  5. Lozzy
    Lol just leave it Nige :rolleyes:
    If there's no salt on it it'll be fine...use it & abuse it and just clean it every couple of weeks!
    Been out on mine all morning and the underneath is pretty much like yours and has been since beginning of Dec.
    No point wetting it...better off going back into the garage dry & bit dirty than have it damp internally during cold weather....unless this is one you've got in't house on't hearthrug ;)
    Anyhow's my best present today was....sunshine and quiet roads and the speed camera chappies on holiday :D
    • Friendly Friendly x 1
  6. ray
    ray Well-Known Member
    Sportbikeshop.co.uk voucher code
    10% off everything
    Code: BOXING19
    Expires 31st December at midnight
  7. bradt
    bradt Elite Member
    Not to be taken the wrong way but not worn a Bell helmet for years. I like the design and will be interested in hearing how you rate them.
    Why did you go for the Bell Nigel?
  8. bradt
    bradt Elite Member
    Ok Nigel can see the reason why now.
  9. Nigel H
    Well I'm still Quick-Shifter fitting.
    I've got all the cables nicely dressed into the space under the air-box.
    I've taken the opportunity to move the Scottoiler, the GPS and the camera cables into that space as well running them out beside the throttle cables so it's getting awfully tidy.
    But now I need to 'fold back' the rubber sheet to get access to the plugs.
    It doesn't want to come.
    It seems to be held down all round.
    All the documentation seems to assume it's simple and obvious.
    I don't want to just pull hard, it isn't that sort of material.
    What will it be snagging on?
    Please can somebody explain why it really is simple and obvious and it's just me being a ding-bat.
    Please....
  10. mk3golfcab
    mk3golfcab Elite Member
    Cautiously stripped the rear end today, need to get the subframe apart to fit the hooks then all will go back together. Bolt in the rear reflector of the tail started spinning so had to smash it off, otherwise not a bad run. Also one of the clips on the tail fairing was broken from it coming off a previous time.
    New tail tidy will look much better!
    then the radiator and exhaust to go!
    Does anyone have the reflector bolt/or a part number so I can replace for if I want to return to stock tail tidy? Cheers
  11. Blade runner 1
    Blade runner 1 Elite Member
    I have been in there twice now on my bike and as I have a poor memory couldn’t give you a step by step guide. However I vaguely remember it tucks under the air intakes and possibly has like a double sided sticky tape holding it in place. Don’t remember it causing me a problem, but you’re correct in pointing out it’s not the kind of material that would withstand brute force. I found I had to loosen off the left fairing and pop the air intake out a bit to get access to the left coil. If you go down this route it may better reveal how the rubber sheet is held in place. Take it easy, you’ll get there.
    Maybe someone with a better memory than me could chip in.
  12. Boothman
  13. raphael
    nice, the preferred colours also
  14. raphael
    If I have to be in work then might as well make a start on polishing all the titanium off the old bike to fit on the new one
  15. kirkwall32
    kirkwall32 Active Member
    Nigelrb, now that's defo NOT a winter hack.
  16. Boothman
    No worries @nigelrb I like the white and it looks a good one - what’s the story behind the km/h clocks
  17. raphael
  18. Nigel H
    YES!
    OMG what a horrible piece of design. You glue something that is inside the frame to the outside of the frame under an air duct that is under the fairing.
    I've done one side but my space is a bit confined so I need to move things about to get the other side apart now.
    The next time it comes back from a service and they list new plugs I shall not be surprised at the labour hours.
  19. Nigel H
    Oh that wonderfully satisfying click as the last plug latches home (pull, wiggle, s'ok) and now the job is just putting things back together again.
    • Like Like x 6
  20. mk3golfcab
    You don’t hang about @nigelrb! She’s a beauty, fancy some billet aluminium exhaust holders ;)
