Thanks for the warm welcome and my first question
Discussion in 'General 1000RR Discussion' started by Wes, Dec 29, 2019.
  1. Wes
    Wes Active Member
    I’ve only owned her for 6 months but over Christmas I had the back wheel out for the second time. The first time was just a tyre change as it was squared off by the previous owners motorway stints. This time was for a new chain and sprockets job. Gold on gold DID courtesy of my boy as a present.
    On both occasions I removed a chain guard fixing to allow me to slide the wheel in and out. The chain guard is a “carbon fibre” type and I think previously the wheel has been forced back in to position without giving it clearance from the guard. This has resulted in a permanent twist or deform.
    I’d really like to get rid of this and I’m thinking of applying some heat to it. It’s not bad, but it’s clearly not right. I was just wondering if anyone has tried this method or could just reason why I shouldn’t even attempt to correct it. I’d rather leave it as it is than throw it away as I’ve ballsed it up !
    Any thoughts appreciated and once again thank you all for your warm welcome.
  2. LRJimmy
    LRJimmy Active Member
    Hey Wes, if its anything like the OEM plastic type they go back to their original form with a good heat from a hairdryer or a gentle heat with a paint stripper but I'm not too sure if the carbon fibre ones will behave the same way. However there is Golfy... @mk3golfcab who machines rather groovy aluminium ones in either black or silver...have a search on the pages but here is some pics
    https://www.1000rr.co.uk/threads/08-aluminium-chain-guards.37216/page-2
  3. nigelrb
    Having seen the way carbon fibre splinters in Formula 1 front wing incidents, my view is that it is very strong, but also brittle. I sure can't imagine that it will bend.
    From my experience, when trying to fit carbon knee inserts into my 2011 fuel tank cover, the damn stuff wouldn't even flex enough the fit into the tabs.:rolleyes: Can you free up the bolt holes just a mm or so so allow a bit more movement to the guard when fitting, and thereby realigning to a better clearance?
  4. Barstewardsquad
    Maybe a daft question but is it actually carbon fibre or plastic with a carbon fibre effect?
  5. CharlieR85
    Hi Wes, welcome. I suspect you might have a carbon effect/finish chain guard that's actually made from plastic. The genuine carbon ones are really stiff and don't really deform. If you remove it entirely and look on the underside you'll be able to see whether it's made from carbon or plastic. If it's made from plastic then yea get a hair dryer on it.
  6. CharlieR85
  7. mk3golfcab
    mk3golfcab Elite Member
    @Wes if you fancy a billet aluminium chain guard send me a pm. Happy to do a deal on the remaining stock I have
  8. LRJimmy
    Well I meant to say it but couldn't be bothered going back to edit it :rolleyes:
  9. Wes
    Wes Active Member
    Cheers for all the replies.
    Agreed, thank you. It could well be plastic/carbon effect type. I made the mistake because it feels very ridged/strong and certainly looks the part. I just jumped to the wrong assumption.
    I’ll whip it off, inspect the reverse and report back either way.
    Good first post anyway .......probably getting it all wrong lol
  10. Wes
    Wes Active Member
    B803CE6C-1AA2-48B4-82E5-DD12D30C5A38.jpeg 3160FC32-1C9E-4DE3-97A6-9066885C5518.jpeg E3914543-8B60-4BAC-A6EE-087C010888A1.jpeg I Sorted my issue with the chain guard which turned out to be genuine carbon fibre.
    I took it off and cleaned off all the chain splatter. I then offered it back up to the bike to see how much I needed to tweak it. I’d decided to give it a go with a little heat applied.
    As I was looking at it I realised that whoever had installed it had installed it incorrectly. Once it had been secured on top of the rear hugger fixing instead of underneath it, aesthetically things improved greatly. Sorted.
    Also finished off with turning my left over DID links into my very own fidget tool lol.
    • Like Like x 7
