Front disc brake dimensions between 06/07 blade to 08/12 blade
Discussion in 'Maintenance' started by Luis Gracia, Feb 20, 2020.
  1. Luis Gracia
    Luis Gracia New Member
    Hello all,
    I umderstand that the 06/07 fireblade have the same diameter disc, number and size of holes. As the lster 2012 fiewblade however im unclear of the offset sizes. Does anyone have the offset sizes for for the 06/07 front disc and 08-12 front disc. Ive literally looked everywhere online and cant find a answer.
    Many thanks in advance
  2. Boothman
    Hi and welcome to the forum
  3. Muffking
    I can't remember the offset, but I know they can't be swapped over as I tried 08 discs on my 06 and they were dragging in the callipers due to the offset being too far out.
  4. Luis Gracia
    Hi and thank you :)
  5. Luis Gracia
    Thanks mate. I did some more digging and eventually found out that 06/07 is 12.5mm whereas the 08-upwards is 15.25mm. I found the measurements on ebay.But yeah i seen your post about it binding. Thats what made me start searching for it
