I ordered myself a fairing kit from China
Discussion in 'Mods, Upgrades, Accessories and Products' started by Andrew, Dec 28, 2011.
  1. Sossige
    Sossige Active Member
    Any pictures off the bike?
  2. pablo
    pablo Active Member
    Be patient mate ;)
    I'ts all boxed up until i brave the cold garage to make a start. I'm hoping to get it done next weekend, just waiting for bungs to turn up. I'll post up pics once it's done...
  3. pablo
    pablo Active Member
    Finished!!!!
    Not bad but not perfect. The air ducts aren't perfect but it'll do for my needs. Got out for a blast last Thursday night but didn't stay out long as it was minus 6 here...
  4. pablo
    pablo Active Member
    Oh, and as you've noticed already, the paint on the screen doesn't quite line up with the fairing. I could have messed about to get it closer but i was bloody half frozen...
  5. ColinBR
    That looks good mate. Good effort in those conditions :)
  6. Andrew
    Andrew Active Member
    That's looking nice.
    Sorry i've been really slack and still not fitted mine yet, I think i'm going to replace all the fairing fixings at the same time
  7. dan.1moore1
    Can we see some better pics please mate ?
    Some side on shots and some close ups ?
  8. zeepony
    zeepony Active Member
    Nice!
    Just some words of my experience, as i removed my Chinese fairings at the weekend and went back to OE. I didn't notice most of these things until i took it apart. The problem areas I had are as follows:
    1) Belly pan was beginning to melt due to the Yoshi pipe sitting slightly differently from stock.
    2) Water ingress into fuel tank catch tray. I believe due to the rubber seal around the filler cap not sitting correctly, water got in and was starting to corrode the tank around the bolts.
    3) Fuel tank cover rubbing on actual tank (not bad but warn the paint through so need to keep an eye on corrosion).
    4) Fuel tank cover lugs under seat were snapped.
    5) Headlight cowl lugs snapped
    6) Under tail 'plate' 3 out of 4 lugs snapped
    7) Tail fairing rubbing on sub frame
    Nothing too bad but keep an eye out, especially on the tank plastics - fortunately, its the easiest bit to have a look at!
  9. crin
    crin Active Member
    Hi all, I'm new to the forum and have just realised I've bought Hondo's Rothmans rep! I can vouch for the kit, assuming it is the same one. Fits perfect and looks the nuts. Just toying with the idea of powdercoating the wheels white and getting a gold rearset. Having trouble with pic upload but will post pics soon.
    Look forward to seeing yours
    Good luck
    Crin
  10. Andrew
    Welcome to the forum mate, i'm just waiting to get a few parts before I fit my fairing kits so I don't have to keep putting it on and then taking it off again.
    I've heard the quality is quite good but I don't want to push my luck!
  11. BLAGGERS
    BLAGGERS Well-Known Member
    Looks like a chinese fairing for mine soon as my back gets better enough to let me earn some wonga.
  12. 1000rr73
    1000rr73 Active Member
    Don't foregt guys if you want a genuine Honda fairing kit for the 08-11 i have a full set in winning red in the classifieds for £425....fab condition and will obviously ft as Mr.Honda intended.
  13. Jamiestrada
    Shameless plug their, but a very good price :) shame I don't need any yet
  14. 1000rr73
    I know, I couldn't resist!
  15. Pinkster1000RR
    Pinkster1000RR Active Member
    I have been toying with the idea of getting a chinese set......but worried about the fittment....Just for TD use.
    Jay
  16. crin
    crin Active Member
    Go for it! But I bet once on, you dont want to take them off!
  17. crin
    crin Active Member
    mine fits great
  18. Alblade
    Alblade God Like
    I've had a set of Rothmans fairings on my Blade since last summer - they look good from a distance but had the following problems fitting them:
    • Almost every screw hole was wrong size or needed larger screws to fit
      Tail unit has never fitted right , but the 08 is a bastard to fit, undertray fitted fine
      bit more care would have fitted belly pan better to side fairings
      LH air ducts just don't line up / fit correctly - major time with dremel may have sorted
      I fitted extra bolts where side fairings and belly pan meet as did not trust the lugs to hold at high speed (since tested at 180 mph)
      Tank cover bolt hole would not line up
      Lug on tank cover snapped (now held with duct tape on inside)
    Overall they have done the job well, refreshed a tired looking bike but without a Dremel I would have been stuffed
    Almost tempted to get another set and sell this set on ebay for £250 - £300 as at that price they are cheap trackday fairings or somebody may have had an 'off' and need some, If I fit a 2nd set I'd do a better job.
