Lockdown- what you done?
Discussion in 'General 1000RR Discussion' started by Paul Longstaff, Mar 28, 2020.
  1. Blade runner 1
    Blade runner 1 Elite Member
    I it’s a fair point. When the hero blobs on my 1100 Blackbird started touching the ground I traded it in for a Fireblade.:)
  2. mk3golfcab
    mk3golfcab Elite Member
    I’ve not really, I can’t get em close :(
  3. Muffking
    Come to Snetterton on Tuesday, you soon will do ;)
  4. PauloHRC
    PauloHRC God Like
    I don't know anyone who has ever extended them....... Bet they look like Friggin stabilisers extended by 100mm!!!:D:D
  5. mk3golfcab
    Mate I would actually love to, but I have work, down for a trackday with you soon though Gary!
  6. Wozza
    Wozza Elite Member
    On the throttle mine has always been fine what engine mode are you in .....yours like mine is a 2018 model and any issues were ironed out ....mode 3 limits the power than it will kick in....
  7. Paul Longstaff
    Paul Longstaff Senior Member
    Power mode 1 traction 3 eb 3 and a2 suspension.
    The throttle response is great in all environments except this issue which occured twice today.
    I'm prepared to experiment and see if I can pin it down as I suspect I'm just being a little sloppy with my hand control and need to be more direct.
    If it's not that then I got an electrical glitch somewhere. I'm also thinking that as it's not serviced yet and some manufacturers use a very thin oil for running in maybe it was just clutch slip under a rapidly cracked open throttle as I I can wind it on slightly more slowly no probs at all.
    Just a thought
  8. Brom66
    Brom66 Well-Known Member
    For what its worth, and if my memory serves me correct, been a long time since last ridden ! :oops:
    My throttle is a bit blah, several stalls misfire... !!!! but then I've got a massive 46 miles and a Rapid Race Module with full system so I put it down to that. Apparently the RRM is self learning and continues to do so. Although the dealer has said it still should be silky smooth while it learns ..
    We shall see .
  9. Wozza
    Wozza Elite Member
    Hmm sounds like first service should help and more miles on both bikes mines on 4200 now and really smooth...
  10. bazzashadow
    bazzashadow Elite Member
    Are they still on?
  11. R.M
    R.M Member
  12. R.M
    R.M Member
  13. MrB
    MrB God Like
    yeah it does doesn't it and I've not been drinking.
    All good.
    [​IMG]Untitled by (MrB), on Flickr
  14. Muffking
    You can can book them, but it doesn't mean that they won't get cancelled 2 days before they're due to go ahead. It's happened 3 times so far.
  15. bazzashadow
    I didn’t know with the corvid if it was still happening.
    One of my mates goes
    I will have to tell him
  16. PauloHRC
    PauloHRC God Like
    What's Corvid...... Don't tell me there's a new virus knockin about?? :confused::D
  17. Barstewardsquad
    No it's groups of Crows and Magpies attacking bikes. Be extra careful with the groups of Crows, they're Murder ;):p
    • Funny Funny x 5
  18. bazzashadow
    Did you hear about the crows that kept getting run over
    They found out the lookout could only say
    Car car car
    • Funny Funny x 3
  19. bazzashadow
    Well spotted nigel;);):p:p:p
    • Funny Funny x 4
  20. Nigel H
    Nigel H Active Member
    At last. It's been just parked up in the workshop since a quick test ride
    to feel out the quick-shifter after I finished fitting it back in February. Finally
    a short buzz out and back over the lovely sunny South Downs.
    Pity you can't see any of the changes I've made but this is looking west from High-and-Over.
    #520 Nigel H, May 15, 2020
    • Like Like x 10
