Soft brake feel
Discussion in 'Maintenance' started by RR7, Apr 21, 2020.
  1. RR7
    RR7 New Member
    It's the lever ratio that magnifies any discrepancy. There's the exact position of the port, the seal, the piston length, the push rod length, and the lever pocket and pivot position. The overall stacked length, actually involved, can vary by 1-2mm easy, just 0.5mm on each part for example.
    I've no issue with the OEM cylinder once the pads engage, and the 19mm version is even nicer, it's just the variability in the feel one unit to the next. Still, if you can be bothered, the adjustable push rod mod cures it.
  2. Grooveski
    Grooveski Active Member
    I've never even tried the OEM.
    When I picked the blade up(in a van) the hoses were 14 years old and the fluid was black gunge. Slapped on the RCS19 straight away along with the braided hoses. :)
    Should be a pretty good match for the calipers on the wee zxr though. There's no way I'll be refitting the piece of junk m/c that originally came on that. ;)
    #22 Grooveski, May 22, 2020
