Pillion peg removal 16/17 v 09
Discussion in 'Maintenance' started by bradt, Jun 21, 2020.
  1. bradt
    bradt Elite Member
    Finally after many many months of indecision have decided to but a 2016/17 Repsol, first job will be to remove pillion pegs. I have removed from my 09 (subframe off etc) is it the same procedure or has the job been made easier on the later bike ?
  2. raphael
    a 16 plate bike I would assume it to be the same as my 15 plate so still a pita,
    A 17 plate is the newer shape which I think is just a simple unbolt?
    If it’s the newer 17 you might want to check the authenticity of the repsol as I don’t think they made a repsol? I’m normally wrong mate but worth checking
  3. bradt
    bradt Elite Member
    When I say 17 plate it will be the older shape this is I want, but appreciate your comment.
    #3 bradt, Jun 21, 2020
  4. PauloHRC
    PauloHRC God Like
    Have you actually bought bought it yet?:)
    But yes same job as before on a 16 plate bike:rolleyes:
  5. bazzashadow
    bazzashadow Elite Member
    Horrible job on a 16 easy on a 17
