Rear tire change video on 2017 cbr1000rr abs
Discussion in 'Maintenance' started by Dr. Speed Lemon, Jun 24, 2020.
  1. Dr. Speed Lemon
    Dr. Speed Lemon New Member
    I made a bunch of how to videos for our bikes and would like to share them. I've used this forum a lot in the past for mechanical guidance and decided to give back to the community. The videos are a little long but I'm sure I'll get better at it. They contain helpful info like torque specs and recommended tools.
  2. simon p
    simon p New Member
    Very interesting way of doing it,
  3. Dr. Speed Lemon
    I'm not an expert by any means but I've done a lot of tire changes. The socket you need for the rear axle is 36mm not 32mm like mentioned in the video. I goofed that part up. Everything else should be accurate though
  4. Selmer50mark
    Advice with a rear stand ,,,, stand at the opposite side to the bikes side stand ,
    That way if you lose hold of the bike while putting the paddock stand in palace the bike can only fall back on to its side stand or against you ,,,,,, and make sure the side stand is down when removing the paddock stand .
    Easy to drop while locating the paddock stand to the bobbings ;)
  5. Dr. Speed Lemon
    Thank you for the advice! I will have to mention that the next time I put the bike on the stand.
