Oil
Discussion in 'Maintenance' started by bazzashadow, Jul 23, 2020.
  1. bazzashadow
    bazzashadow Elite Member
    This has been done and done and done:rolleyes: I’m sure
    But the garage I used for my last service used putoline syntec 4 and I was going to use the same but it looks like it does not exist any more.
    Is there an alternative?
  2. Selmer50mark
    This'll be a good debate Bazza ,,,,, I get Castrol Power 1 Racing 10W/30 ,,,,, did think about 10W/40 :confused:
    Some say one ,,,,, some say the other o_O
  3. dfw100
    dfw100 Active Member
    My two penneth: I either use Motul 7100 or Silkolene Pro 4 as both are full ester synthetics, and are usually readily available. I prefer 10w/40 in the interests of reduced oil consumption.
  4. bazzashadow
    Mine has not used a drop and the oil is still clear (16 plate 10000 miles 3000 this year)
  5. TheMickster
    TheMickster Active Member
    I use Motul 300v in mine . Used Silkolene Pro4 in the past too.
  6. Kentblade
    I have been using Silkolene Comp 4 XP for a few years now, Probably like most peeps choice of oil, not had an engine let go yet, so must be sort of OK I guess.
    • Old Old x 1
  7. Selmer50mark
    What grade ? Just Curious :)
  8. Kentblade
    As per Hondas recommendation, so on the 1000s 10/30, on the older bikes 10/40
    When you look at the manual they overlap, in the operating temp, but being no oil expert, I just follow the book.
    I have a couple of litres in the for sale section as the 1000s gone.
  9. Selmer50mark
    Yeah , the over lap , :confused: Haynes reads 10/40 .... bike guide reads 10/30 :rolleyes:
  10. bazzashadow
  11. Empty_Ten
    Empty_Ten Active Member
    I've been using Motul 300v 10w/40 in mine. No issues with it and I plan to keep using it.
  12. simon p
    simon p New Member
    Castrol Power 1, 10/40. If you read about oil on any forums it will do your head in. I went with what I usually buy for my bikes. :D
  13. Blade runner 1
    Blade runner 1 Elite Member
    Currently Silkolene Pro 4 10W-40 as it was free. Either 10W-30 or 10W-40 will be fine in this climate.
  14. Paul 123
    Paul 123 Active Member
    I always use 10/40 semi in my bike and in my oid cbr600rr, never had any issues, to be right I think all oils are pretty good these days,but that could be another debate!!!!!!.
  15. Kentblade
    I stand to be corrected here by an expert, but manufacturers specify the oil for the region in which the bike operates, which is largely based on average ambient temperature due to the changes in viscosity at a given temperature, and listed as a figure ie 10/30, that gives rise to multi grade oils as almost most wear is from a cold start, so a single grade in modern engines with the wide temperature operating window and ability to rev highly would not be beneficial to engine protection and longevity, and also specify the minimum standard ie the JASO/MA and the API quality level, once you have got that, then in my eyes any oil meeting that standard can be used and should perform the same and be able to be mixed with other manufacturers oils of the same grade and spec, and then it’s a matter of personal preference as to what you brew you like.
    So there’s an awful lot of marketing BS that goes into the sales blurb to tempt us to purchase one product over another and like all sheep I happily follow my favourite food without question unless something goes awry and I get a gut ache or the trots.
    Disclaimer, the above maybe total bollox and I have got it completely wrong, which according to Mrs KB is a daily occurrence, so might be safer to make up your own mind what’s best to stick in yer pride and joy.
    • Downvote Downvote x 1
  16. LowSide76
    LowSide76 Active Member
    is there any actually benefit between the 10w30 and 10w40. All my old bikes have used 10w40.
    Is it actually a big difference for fuel economy on 2015 blade i have or is it negligible
  17. Boothman
  18. bazzashadow
  19. mbooth1
    mbooth1 Active Member
    Motel 5100 10W-30. Always. In pre-1000 models and 600F 10W-40.All a question of personal preference, like Tyres (always Bridgestones for me).
  20. Slick
    if i intend to bounce off the redline track days etc then motul 300v otherwise castrol racing semi.
    if i change just before summer 10w40 otherwise 10w30
