Air box flapper mod
Discussion in 'Mods, Upgrades, Accessories and Products' started by Shaun88, Sep 12, 2020.
  1. Shaun88
    Shaun88 New Member
    Morning all I’ve been doing a lot of reading regarding the flapper mod in the air intake, but not sure weather to go ahead with it. my bike is stripped at the moment as I’m replacing the complete fairings so thought it would be the ideal time to get rid of it. Which is the best way to go about it remove all the parts and just plug the vacuum tube and do I need to get the Actual flappers out of the air ducts or can they stay in with the other roads removed? cheers in advance.
  2. dern
    dern Well-Known Member
    Just plug the hose and see if you can feel any difference and therefore whether it's worth taking all the bits out. I ran it like this for a bit and couldn't feel any difference on track so just put it back together next time I was servicing it.
  3. vic_ster51
    vic_ster51 Active Member
    Flaps will stay in, as they will lay flat. Remove everything else, simple to do when off bike. SIlver solenoids turn and pull out, remove the spring, remove the bottom triangle tank thing. (cut the little mount tab off as you can use this) Tape up the holes. Remove all wiring and crap linked to it. Block the vacuum tube to injectors with screw and cable tie.
    Less crap around bike when doing things later to it. Its just all emissions. Air intake sounds better too
  4. simon p
    simon p New Member
    I done mine a few month ago, hadn't had the the bike long, 2010 model gains for me are taking the fairing off and on, no wires getting in the way. Plus I have more room in the lights department if I want to upgrade to HID's, another thing to put on the list to buy,
  5. simon p
    simon p New Member
  6. Shaun88
    Shaun88 New Member
    Cheers for all the reply’s I took it all
    Off much less messing about in future.
    cheers all
  7. Sam.moz86
    Sam.moz86 Active Member
    Other than what's been stated, RE refitting the fairings, what's the benefit to this mod? Is it the same for the 2015 model?
  8. CharlieR85
    CharlieR85 Elite Member
    The only slight difference is the triangular shaped resonators that sit below the air ducts don't have anything to do with the fairing fittings like they do on the earlier blades. There are plenty of posts (including @vic_ster51 above) that mention having to cut a tab off the resonator. This isn't applicable on a 2015 bike.
    I don't think there is any gain to doing this mod other than removing clutter 20201204_194040.jpg
  9. Sam.moz86
    Gee Whiz! Is all that to please the green police?
  10. CharlieR85
    Yes, 3 systems there. The triangular pods are resonators, the 2 metal caps with pipe work is the PAIR system and the rest is intake flapper system.
