Please refresh my memory
Discussion in 'Maintenance' started by bonjo, Sep 27, 2020.
  1. bonjo
    The exhaust valve on my rr8 is supposed to open aa@ 4000rpm.
    Any way to check this on a stationary bike?
    On the move, I can hear the tone change but in neutral nothing happens at 4000.
    Old age memory loss:(
  2. Stuish
    Stuish Senior Member
    I think the only way is to run it on a paddock stand in first, obviously would not recommend this however :eek:
  3. Muffking
    As above, on a paddock stand.
    I'd have no issues with this as long as it's stable. Short of having a rolling road to hand it's the only way to check such things, like a quick shifter. Just don't go oiling the chain with it running on a paddock stand :eek:
  4. Blade runner 1
    Blade runner 1 Elite Member
    The change in tone will probably be a good indication that it’s opening, personally I would disconnect the cable and forget about it.
  5. bonjo
    So am I right in thinking it does npt open if the bike is standing and just reving the engine?
    I ran it with the cable detached (after the silencer was renovated) but honestly the noise was too much and overpowering. I like to sound of the front end: engine, gear whine & gear changes.
    So I have reconnected it!
  6. Stuish
    it will open, if it's on a paddock stand, in first with the wheel spinning, but not in neutral, no.
  7. bonjo
    Thanks pal; this is the clarification I was after:)
  8. dfw100
    dfw100 Active Member
    It will open, even in neutral. Pop the cover off the servo and behold the wheel moving.
  9. bonjo
    :confused: well, I tried it on the paddock stand, neutral, side stand up. Ignition on, the motor moved slightly to take up the cable slack.
    Engine on, revs up to 4 k: nothing.
    I selected 1st gear, then chickend out above 2k rpm!
    However riding the bike, I noticed the exhaust note change only in 6th gear and as expected there was some hysterisis designed into the operation.
    Kind of makes sense since in lower gears, you can shoot past the 4k threshold very oftern and quickly and the servo motor does not yoyo open/ close.
  10. Stuish
    It 100% opens in the lower gears, cannot recall if 1st does, but 100% should in 2nd, 3rd and above.
  11. bonjo
    understood. I'll challenge my degraded hearing:( when I next go out.
    BTW I am talking about 2008 bike (just in case)
