How long does stuff last
Discussion in 'General 1000RR Discussion' started by Boothman, Oct 16, 2020.
  1. Boothman
    Just curious for how many miles things last in general when doing ‘Normal Riding’ (so not track days). Such as front and rear tyres, front and rear brake pads, chains, sprockets, etc
    Obviously, there are many after market options so let’s stick with OEM parts for the purposes of this exercise. However, I’d be interested to know what people are replacing said with if not OEM.
    My 2016 has done about 4500 miles. Rear tyre was replaced when I picked it up as it had been squared off rather than run out of tread and the original front is going to need changing in the next few hundred but everything else appears fine. I’ll get a better look at the front pads when the wheel is out and I strip/clean the callipers.
  2. bonjo
    IMO this is almost the same as how long is piece of string.
    Your total riding weight
    Your riding style: ON/OFF or smooth & progressive
    Your routes: high speed motorwar, congestes traffic, A/B roads with good bends
    The state of regular maintenance Tyre pressure, chain slack...
    In my case my weight is on the low side, I plan A/B roads and avoid congestion or motorways, my tyre pressures are 1~2 PSI below recommended levels.
    So after 16k, my chins has not even entered the green zone (I run my slack @ 30~33mm), brake pads have plenty of meat left. Tyres last around 5~5.5k (strangely front & rear wear are very similar!).
    Except for tyres I intend to stay with OEM
    No doubt there are other factors not mentioned; but then it would become as long as a piece of string:)
    • Agree Agree x 3
  3. Lozzy
    Spot on....my chains and tyres identical on both bikes but I ride the sp harder...lower gears more often etc etc. The slack needs taking up more and the tyres don't last as long....oil gets gobbled.... and that's just with a onky slight change in riding. The pads wont last as long either.
