2009 exhaust infill
Discussion in 'Forum Announcements' started by Rr9, Oct 9, 2020.
  1. Rr9
    Rr9 New Member
    Hi everyone
    I'm after a exhaust infill 2009 honda cbr1000rr fireblade if anyone can help !
    #1 Rr9, Oct 9, 2020
  2. PauloHRC
    PauloHRC God Like
    Just get in touch with Racefit or order one of their website ;)
  3. PauloHRC
    PauloHRC God Like
    Try posting stuff like this in the 'mods, upgrades' section, you'll get more views/responses ;)
  4. Boothman
    Hi and welcome to the forum
  5. Rr9
    Rr9 New Member
    Do they fit any exhaust
  6. PauloHRC
    PauloHRC God Like
    Depends what sort of exhaust you Got, put a picture so I have an idea?
  7. Rr9
    Rr9 New Member
    Please see photo and many thanks for your help
  8. PauloHRC
    PauloHRC God Like
    Yes you should be fine with that. From memory the bracket that comes with the panel fits just in front of the wishbone and holds the infill panel flush with the belly pan. Your exhaust should not interfere with that, it's when you have one of those pig tail curly link pipes like what you get with an Akrapovic which leaves no room for the bracket.;)
  9. PauloHRC
    PauloHRC God Like
    Nice bike by the way......;)
  10. Fwsock
    Fwsock Active Member
    Got one on mine. Go take a look
  11. Rr9
    Rr9 New Member
    What make is yours
  12. PauloHRC
    PauloHRC God Like
    The one I've shown you is the only one available for a 2009. Fwsock has a later model blade so that one won't fit, or at least it won't marry up to your belly pan properly.
    Leo Vinci do an infill panel too but there not as easy to get hold of.
  13. PauloHRC
    PauloHRC God Like
    Leo Vinci one on ebay. Bit dearer though!
    20201018_104305.jpg 20201018_104328.jpg 20201018_104416.jpg The problem you have is with your exhaust, the Racefit one is design for Racefit exhausts and the Leo Vinci one ......Leo Vinci exhausts. Your Pipeworx can was probably never designed with an infill panel in mind, that's why there's none on the market. But I would say that the Racefit one is the most likely to fit as it has an independent fixing bracket which should be clear of where your exhaust is positioned. Now just go buy it and stop dilly dallying ;):D
  14. Fwsock
    Mines a racefit fitted by them along with the pipe. There’s always the world of dremel. Can make anything fit. :D
  15. Rr9
    Rr9 New Member
    Aha thanks racefit exhausts has a bracket welded to to exhaust the two front fixings should be fine .
  16. Iain
    Iain Active Member
    What are you on about?
    As you already have been told, the racefit panel is supported by a bracket which has been designed to clear the exhaust . The way the exhaust curves takes into account of clearing the infill panel..Yhe only bracket on the exhaust is one to support the exhaust on the footrest bracket bolt.
    The ugly monstrosity you have is likely to foul on an infill panel, which is why you cant find one. You may be able to dremel the racefit one, or even bend the bracket, and the only way to find out is to give it a go.
    • Friendly Friendly x 1
