hugger problems
Discussion in 'New Members' started by andy milner, Nov 10, 2020.
  1. andy milner
    andy milner New Member
    Can anyone help i want to buy a rear hugger for my 2016 repsol SP and keep coming up with noting.... does anyone know where i can buy one please help would be really appreciated
  2. Selmer50mark
    Hello and welcome, ,,,,, try Powerbronze
  3. mk3golfcab
    mk3golfcab Elite Member
    Hi and welcome, R+G, powerbronze, Honda, etc etc. What sort of hugger are you after?
  4. andy milner
    Thank you for the reply...I'm looking for either a repsol hugger or a red hugger I've been told because of the abs a hugger is not advisable....I've seen a 2015 repsol hugger non abs and wondered why that would not fit or could it with adjustments ?
  5. Iain
    Iain Active Member
    It will fit fine, but the ABS unit will hit the hugger when the suspension is compressed.
    If you are light, and increase the preload it might be ok. But at the full limit of compression, the ABS will hit the hugger.
    I have had a King Carbon hugger on my 14 ABS since it was new, they say it is fine for the ABS model, but mine has hit the hugger a few times, luckily it has flexed a bit and not totally broken it yet, but there are a few small crachs on the hugger.
    #5 Iain, Nov 11, 2020
  6. Lozzy
    You need the abs specific one as it's to take into account the abs control box under the seat area not hitting your hugger under compression. I put a carbon one on my old abs repsol and it looked good with a matching front one just in case you can't get the colours you want...
  7. dfw100
    dfw100 Active Member
  8. Boothman
    Hi and welcome to the forum
  9. cronester
    cronester Active Member
  10. dfw100
  11. BlackDevil
    Hi and welcome !
