2005 fuel tank overflow issue
Discussion in 'General 1000RR Discussion' started by Dazb13, Dec 19, 2020.
  1. Dazb13
    Dazb13 Active Member
    Evening all. Any of you fellow blade peeps got a 2005 blade and can post any pics of the overflow lines under the tank. I've added a pic if you could tell me its OK or not. Theres 2 open ends. Cheers
  2. Kentblade
    Mr Haynes view of the world
  3. Dazb13
    Thanks. RR6-RR7 different setup to the RR5 ? Or all the same ? I take it the tube/pipe that disappears over the number 2.8 is the breather not connected to anything
  4. Kentblade
    I’m sure you will find the 4-7 the same.
    The hose in question at 2.8, should be the breather hose that exits under the bike by the side stand.
  5. Dazb13
    Thanks. The larger hose that comes out of the tank to the "T" piece in the picture is connected to the the long breather hose by the side stand. So the smaller one i mentioned is also just open under the tank ?
