  1. bazzashadow
    bazzashadow Elite Member
    Yer yer yer jimmy hill;):p:p:p:p:p:p:p:D
    • Funny Funny x 3
  2. Sam.moz86
    Sam.moz86 Active Member
    Where did you get the QS from? I'm looking at HPS now as they're offering 10% off.
    Looks a lot better IMO.
  3. CharlieR85
    CharlieR85 Elite Member
    Yes I got mine from Bike HPS too. Got 10% off but had to order it over the phone. No problem with their service...excellent next day delivery although it wasn't free which is a bit crap on something so expensive.
  4. bazzashadow
    what ones did you use?
    But I’m not sure I can use led’s with the twin headlight conversion, but might be worth a look
    #10984 bazzashadow, Dec 26, 2020
  5. Barstewardsquad
    I know what you mean about shipping, but at least they don't use Hermes or Yodel and charge you like DPD/UPS.
  6. Glenandemm
    Glenandemm Active Member
    What
    What bulbs did you use pal?
    Looks much better than the classic yellow light!!!!
  7. mk3golfcab
    mk3golfcab Elite Member
    You can’t unfortunately Bazza :(
  8. Sam.moz86
    Tell me about it, I thought it was a little cheeky. I added it to their comments part on how can they improve.
    I'm not sure about the dual headlight module. I use this little business
    https://autoleduk.co.uk/
    I've used his bulbs in my cars and other bikes. His Comms and delivery are good, and sometimes runs a flash sale. Best of all, they come with Haribo's :D
    Cheers, I can't stand standard halogen bulbs.
    They're a little tight getting the clip fastened, but a little persuasion with a pair of pointy nose pliers did the trick.
  9. Selmer50mark
    16,000 shim check on the RR7, ,,,, No4 exaust gaps are tight by 0.02 mm ,,,,,, the rest are within tolerance.
    Question is do I replace the shims for such a small amount :confused:
  10. Boothman
    IMHO - If you’ve got it stripped to the point you can check then surely it’s not much more effort to change the two offending items to be mid tolerance Mark o_O
  11. Selmer50mark
    Might as well get them all to mid tolerance because the rest were closer to the tight side ,,,,,, the inlets should be 0.13 -0.19 ,,,,,, iv got 0.15 across all 4 cylinders.
    Exaust should be 0.27-0.33 I've got 0.28 on cylinders 1,2,3 and 0.25 on No 4 .
    I'm quite surprised how close to being out they are ....... worth checking at the recommended intervals
  12. CharlieR85
    This is where all the peril is though removing the cam sprockets and cam shafts! :eek: Good luck.
  13. kev.b
    kev.b Well-Known Member
    Started an cleaned the Blade today, Been stored for a while. :)
    • Like Like x 6
  14. tuktuk
    tuktuk Elite Member
    That garage is too tidy!
  15. CharlieR85
    Looks like a nice garage, not nearly enough bikes in it though!
    • Agree Agree x 3
  16. Selmer50mark
    Cracked on with cleaning snd servicing the rear suspension ,,,, some pics ;)
    20201230_145034.jpg 20201230_151354.jpg 20201230_160345.jpg 20201230_161422.jpg
    After 16000 miles the bearings were in good condition, ,still had plenty of grease in them ,,,, just smeared a bit more grease in :)
    • Like Like x 12
  17. PauloHRC
    PauloHRC God Like
  18. Selmer50mark
    The Mrs has just noticed her Emma Bridgewater tee towel in the pic :oops::D:D:D
    Time for a bollocking :rolleyes:
    • Funny Funny x 8
  19. PauloHRC
    PauloHRC God Like
    Well if she was in the kitchen washing and drying the pots like she should be, you wouldn't have had access to that tea towel so its her own fault for leaving it unattended!!!:rolleyes::D
    • Funny Funny x 8
  20. Sam.moz86
    Nice job that. Do the linkages get serviced at regular intervals with the main dealer?
    My old Aprilia had to be done annually.
    I didn't touch mine today, but I did receive a present for it
    • Like Like x 6
