Flapper mod question - 2006
Discussion in 'General 1000RR Discussion' started by Wayne Steele, Mar 7, 2021.
  1. Wayne Steele
    Wayne Steele Active Member
    Apologies guys if this has been over talked about again and again.
    I have an aftermarket can on the bike and the cables for the flapper valve are still on the bike and tucked under the heat shield. I was trying to work out how to get to the pulley so I can completely remove the cables but cant see and easy way to do this. I believe the pulley is near the battery but I can't see how to get to it. Do you have to move the plastic under the battery to get to it? The haynes manual hasn't really been much help
    Thanks in advance
  2. mick66
    mick66 New Member
    I can only tell you in the 2013 it's a case of removing the undertray.. it's behind the back plastics exhaust side...
  3. GappySmeg
    GappySmeg Well-Known Member
    The flapper mod generally refers to the flaps in the intake, in front of the air box.
    You seem to be referring to the exhaust valve servo?
    If I've got you right, then it is located in the battery compartment, under another cover if i recall, and quite easy to get at. Certainly i did mine using just my Haynes manual.
    If you remove the servo/pulley you will need a "servo eliminator" to stop warning lights appearing.
  4. Wayne Steele
    Yes apologies that's exactly what I'm referring to
  5. Jez
    I have just removed the cables so no need for eliminator, it is then easier to refit if you want to sell etc
  6. Blade048
    Blade048 Active Member
    This video might help you.
  7. Wayne Steele
    Blade048 that's exactly what I need thanks
