Brake Lever guards for trackdays...
Discussion in 'Mods, Upgrades, Accessories and Products' started by Frazzle, Nov 24, 2020.
  1. CharlieR85
    Gibernau, Spain, 2006. I've won your V4 yea?
    • Funny Funny x 4
  2. PauloHRC
  3. PauloHRC
    This is the standard insert off my Ducati, its quite substantial and has got a good bit of weight to it. I had to buy a longer 80mm M6 bolt as the lever guard came with an M8 bolt. I managed to find an Oxford products set of bar ends that were similar in finish and weight so matches up ok I think.
  4. tuktuk
    tuktuk Elite Member
    Just watching the build up to the moto GP and see the close racing in moto3 with lever guards pointing the sky after a few bumps.
    I can see how these help and yes if it goes wrong on a track day it may help but surely it makes far more sense to get it into people heads that a track day is not a race meet and the number 1 priority should be respecting other peoples space.
    If at any point you put yourself or someone else in the position where a lever guard can stop a crash just have a word with yourself and if you dont have the special awareness required the stewards should be pulling people on it.
    • Agree Agree x 4
  5. PauloHRC
    They're like a 'use once' piece of equipment.......just about does its job and is rendered useless after a collision.......
  6. markshu
    markshu Active Member
    Hi so I need to get a brake guard too for my Honda which is the 2015 model. I can’t believe how hard this is proving to be . I am not certain that the German product is suitable , any advice comments appreciated. I certainly think a pair is better than one due to the weights , thanks .
  7. Frazzle
    Frazzle Active Member
    Fitting them can be a bit fiddly, depends if you intend on taking the weight out or just doing the fix that Dern described earlier... R & G will fit, as will lightech, Acossatto and most others I expect or you can just grab an ebay one and save a load of cash? .... I've not bothered doing both, I've also not noticed an more vibes in my bar which is essentially what they are there for....
  8. dern
    dern Well-Known Member
    As a follow up the bodge I did worked fine on track. It didn't move or vibrate and taking one bar end off leaving the insert in place had no ill effects. The cheap crap grub screws did vibrate out on the trailer on the journey there though. Fortunately I had the two from the other side and just taped it all together to stop it happening again. Even with the tape they didn't look twice at it when doing noise testing.
  9. markshu
  10. markshu
    I think I might try out the ones with the German company as I want a pair .
  11. NS400R
    NS400R Elite Member
    Well I've decided on Dern tribute. I want the ability to swap easily between road and track. So like Dern I leave the Honda insert in, but instead of a screw, silicone seal the thing in place to stop it moving about. R&G guard screwed in with washers used as spacers. Seems solid enough.
  12. NS400R
    NS400R Elite Member
    This us how to get the insert out according to Honda
  13. dern
    That’s good idea.
  14. keithg1748
    keithg1748 Active Member
    well it took about 10 mins to release the inner bar and couldnt believe how easy it was , thank fuck , so its time to look for a brake lever guard , happy days. , so what size do you need to fit ? , thanks
  15. keithg1748
    just ordered one of these in black £34.99 , the guy was really helpful , he also does them in ti grey colour as well. . see what its like when i get it and fit it .
  16. MarkB852
    MarkB852 Active Member
    I expressed a similar opinion elsewhere and was told it was because of a fatality at Snetterton turn 2 hairpin. It seems that a lever guard would have prevented the incident.
  17. keithg1748
    fitted , good quality .
  18. dern
    Looks good. What grips are you using?
  19. keithg1748
    renthal .
  20. dern
    Are you pleased with them? The OE one on my bike are feeling a bit old. Did you go with medium or soft? Thanks
