Fenda Extenda
Discussion in 'Mods, Upgrades, Accessories and Products' started by Dogsbody, Apr 20, 2021.
  1. Dogsbody
    Dogsbody Active Member
  2. Boothman
    Put one on mine two years back - keeps more stuff off the rad than without
  3. bonjo
    fitted a pyraming as well in 2008!
    you have to be carefull with the clearances as there is not much there!
  4. Broadie
    Broadie Active Member
    Any recommendations on fitting? I've glued and riveted on other bikes.
  5. bonjo
    From memory, it had a sticky strip and some metal fasteners.
    I would swap the fasteners for S stell ones.
    I have never used rivets before:eek:, just make sure the process does not crack the mudguard
