Fork Seals
Discussion in 'Maintenance' started by Ali Smyth, May 28, 2021.
Tags:
  1. Ali Smyth
    Ali Smyth New Member
    Hi all,
    I have a weeping fork seal and so removed the forks to get the seals replaced. Post removing the forks I noticed there was a thin metal ring (split) in a groove on one of the forks. I had a good look for one on the other but couldn't find one. (see pic).
    What are these for, are they necessary and what are they called if I need to replace the missing one.
    Thanks in advance
    Regards
    Ali
  2. Kentblade
    They are the retaining springs, where you push them into the groove in the triple clamp to make sure they are seated correctly. Always possible to have one that’s gone missing from previous work.
  3. Ali Smyth
    Do I need them? If so any recommends where I can get them
  4. Kentblade
    What model/year and post up pic of groove in fork
  5. dern
    dern Well-Known Member
    I don't think that they perform any function other than locating the fork in the default position. If you have one then you can use that fork as a reference for the second. Keen to be corrected if that's wrong but I wasn't concerned when one fled under the workbench when I did mine although I did recover it and use it in the end.
