Pics/Advice wanted - 1000rr 2008 - Bazzaz ZFi TC install
Discussion in 'Mods, Upgrades, Accessories and Products' started by martin_deyanov, Jun 6, 2021.
  1. martin_deyanov
    martin_deyanov Active Member
    Hi folks,
    I am in the process of installing a complete Bazzaz ZFi TC unit, along with the quickshifter, TC and Map switches, TC Active light and the Z AFM Mapper module.
    Now, I have no problem wiring the system, in fact I have already installed the fuel and injector harnesses around the airbox and coils, tucked and secured everything in place. Connected everthing else and the bike starts and runs fine.
    The problem I am having is routing and positionig the modules in the tail section. My OCD requires everything to be tucked and positioned nicely without having a spider nest of loose cables and dangling modules.
    So for those of you that have the system installed, I would appreciate advice about how it is positioned in the tail section and ideally pictures if you have them. Mine is a track only bike so I dont have the stock plastic undertail in the passenger seat area.
    Thanks in advance.
  2. jokeshopbeard
    jokeshopbeard Active Member
    LOL that's a fuckton of cunty wiring you have there. I don't think there's any advice anyone could offer aside of setting it up neat as possible in the tail section.
    Looks like you've already done a fine job of staying neat over the injectors, so just carry on, I guess?
  3. martin_deyanov
    Well, I'm looking for ideas and existing installation photos, so I can minimize the time staring at the tail section and scratching my head...
  4. CharlieR85
    Have you removed the exhaust valve servo motor from underneath the riders seat? That clears a decent amount of space. I've got my quickshifter ECU in that space and my PCV in the tail where the toolkit should be.
  5. jokeshopbeard
    You can get room for the PCV/Bazzaz in the battery bay if you switch to lithium.
