Chain tool
Discussion in 'Maintenance' started by dern, Jun 7, 2021.
  1. dern
    dern Well-Known Member
    I've never bothered with a chain tool, preferring to use an angle grinder to cut the old chain and then spread the link using a ball pein hammer and a lump hammer as an anvil. I used to have a cheap chain tool that broke while I was using it smacking my thumb so hard I could swear I'd bust a bone or something.
    Anyway, I bought a motion pro chain tool to change my chain this weekend and it's a fantastic bit of kit and made the job so much easier. I still grind off the spread ends of the pins but other than that I use the tools to push out the pins and fit the new link.
    Just thought I'd mention it if anyone needs one. Worth getting if you wanted a tool to last for more than one chain.
    Cheers,
    Mark
  2. Blade runner 1
    Blade runner 1 Elite Member
    Good to know. Last time I changed a chain (which was quite a few years) ago I used a sealey chain tool which broke. I ended up using a ball pein hammer in the end. I reckon my chain is due for renewal in the next year, so it’s good to have a recommendation.
  3. warren smart
    warren smart Active Member
    I’ve got two depending on what chain I’m fitting, if it’s a solid pin I use the whale tool and if it’s hollow pin I’ve got the did kr500 tool, taking chains off it’s a slitting disc.
  4. Slick
    Agree, I do go for DID chains for the hollow link, rather than Tsubaki etc due to the solid link, rather impressed with the cheapo ognibene chain tool, really hard to screw it up
  5. Kentblade
    Used the same KM500 chain tool for over 25 years, still on the original pin, must have done 40-50 chains the amount of times cheapskate mates have borrowed it, bulletproof piece of kit.
    But Mark you just give me an idea for next the next time someone asks about chain splitting....angle grinder and 2 fuck off hammers.....quality, no more lendy the KM500 :D
  6. dern
    Works a treat until you run out of thumbs.
  7. bazzashadow
    bazzashadow Elite Member
    I think all of them advise to grind the heads off the link first before pushing out, but what I would like to know is what motion pro did you get?
    Just googled them and there are a few
  8. bazzashadow
    I do like the look of the DID because it supports from both sides so must make it harder to bend
  9. dern
  10. Hondaboy63
    Hondaboy63 Active Member
    Im in the throws of changing my chain. I use a dremmel drill, to remove the overlap. I have the correct seally VS779 chain breaker. But im struggling to push the link plate on. I spent 1hr trying, and gave up. Im now contemplating skimming the pins or holes down. Next option is take it to a garage, which is frustrating to show my inadequacy. Any advice.
  11. dern
    Are you using a new link or reusing the old one?
  12. warren smart
    There’s you tube videos on how to use it.
  13. Hondaboy63
    I bought a new link, and checked the chain markings, before I purchased. Im actually so frustrated im going to install my new 3D chain, that I have spare. I checked the YouTube videos, it states it should initially press on the pins before you need to press with the tool. It keeps falling off. Ive change a chain before with ease.
  14. dern
    Weird. Sorry, can't really help. However, if you have the tools and know what you're doing it might suggest that there's an issue with the chain. Good luck.
  15. warren smart
    You need to check the link you have bought, a did 530 link is different to a tsubaki or renthal etc.
  16. Hondaboy63
    Thats a reasonable shout. I assumed I ordered the correct link. But it could easily be non compatible. Its normally the simple solution. It gives me hope.
  17. warren smart
    Checking it is mainly that the pin isn’t to small for the chain you have, they are different sizes between brands as I found out, the link I bought wouldn’t go through my chain but luckily my local shop stocks different links, whichever brand link you have bought should press onto itself, sometimes it just takes a little time to get everything lined up correctly as I’ve found out and is a sticky messy job.
  18. warren smart
    Just to add, in the past if I’ve had an awkward side plate I’ve used some mole grips to just start it on the pin before I’ve used the chain tool.
  19. Hondaboy63
    Nice 1. Ill be checking tomorrow.
  20. dgr
    dgr Active Member
    Bolt cutters for removing an old chain. Takes about 30 seconds and no mess.
