  1. BladeOfGlory
    BladeOfGlory Active Member
  2. bazzashadow
    bazzashadow Elite Member
    Cheapo off ?
    Can’t remember :p:D:D:p:p
    Off here I think
    #11462 bazzashadow, Feb 22, 2022
  3. BladeOfGlory
    I have the plug - just went and checked, so going to order those bits. Presumably its wired to the brown&white (ignition switched 12v) and the green (earth)? How did you blank off the other connectors?
  4. CharlieR85
    Yes just pin up the 2 wires, the rest just leave blank...the connector will come with 6 blanking plugs to go in the back of the plug, you'll use 4 of them.
  5. SimonRR
    SimonRR God Like
    forks and shock serviced, valve clearance checked, new oil and filter, cleaned AF, new tyres SP V3's, new fairing coming soon, a good clean and then ready for 2022 fun :D
    • Like Like x 6
  6. bazzashadow
    It comes with blanks
  7. BladeOfGlory
    Bit of a spin out this morn and then snazzy new levers fitted
    130648EA-FC76-4E32-9E5B-41C2C2C3291F.jpeg B92040A3-BE33-49A9-BFFD-A42BE415AC71.jpeg
    • Like Like x 7
  8. gRRandeelion
    gRRandeelion Active Member
    Nice looking pair of levers, make and price?
  9. gRRandeelion
    Don't worry, just seen your other thread thanks.
  10. Selmer50mark
    Oil & filter change and PITA Datatool alarm removed ,,,,,, 20220227_161615.jpg
    Not a big job to remove or reinstall.
    • Like Like x 7
  11. Barstewardsquad
    Oil and filter, but no alarm to remove ;)
    So easy to do on a naked bike!
  12. PauloHRC
    Started it up, revved it up a bit, took a photo.....
    • Like Like x 8
    • Friendly Friendly x 1
  13. Selmer50mark
    Thanks @PauloHRC for the link for the mesh ;)
    Made a new rad guard, the old one restricted air flow to much at slower town speeds on very hot days
    • Like Like x 9
  14. PauloHRC
    Nice job @Selmer50mark , I wanted something similar for the edges and that looks good but would have been too thick for mine!:)
  15. raphael
    Looks a top job and actually smarter that the likes of R&g
  16. raphael
    Fitted this cracking bit of kit
    • Like Like x 6
  17. raphael
    Would you mind sharing a link please mate?
  18. Selmer50mark
    #11478 Selmer50mark, Mar 5, 2022
    • Thanks Thanks x 2
  19. BladeOfGlory
    Good weekend of tinkering: got the bike back from the garage - valve clearance checks (all good) and fresh plugs - plugs made a massive difference, feels much much smoother, couldn’t believe it.
    Then I put a fresh air filter in, and wired in a usb charger.
  20. BladeOfGlory
    Currently fitting Samco hoses to my ‘08 but having real issues getting the left hand one on properly. Has to go round quite a tight bend and it’s barely moving.
    Any ideas anyone?
