Rear Indicators not working ?
Discussion in 'General 1000RR Discussion' started by Paulo4480, Apr 18, 2022.
  1. Paulo4480
    Paulo4480 New Member
    Hi Guys.... Went for a spin. Got home and found that the rear indicators had stopped working. Any ideas?
    Possibly a fuse but fronts are working, lights are working, tail light & brake light working.
    Just no rear indicators.
    Possible separate flasher relay for rears?
    Any ideas?
    Thanks
  2. Blade runner 1
    Blade runner 1 Elite Member
    Hello and welcome. What year is your bike? Does the front indicators flash quickly since the rear indicators stopped working? Do you have led indicators fitted? It’s one circuit for the indicators so one fuse and one relay. Could be a bad connection to the rear indicators.
  3. Trackit
    Trackit Active Member
    Probably the plug under the rear seat cowl that is corroded.
  4. Paulo4480
    Hi. Its a 2010. Not LED. Yeah the fronts flash really quick. I think I may have found the issue. As 1 of you mentioned, both wire connectors under the seat cowl are faulty. When I moved the wires about they both started working. I'll need some new connectors. Thanks for your help. Appreciate it
