ABS removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolPaul, Jan 6, 2015.
  1. Coda
    Coda Active Member
    Looks like you are making a CB1000RR :)
  2. CharlieR85
    Now that's a huge pussy!
    • Funny Funny x 3
  3. Coda
    Coda Active Member
    I thought that was the owner....
  4. Myblade
    Myblade New Member
    Meeoooowww!
    • Downvote Downvote x 1
  5. Myblade
    Myblade New Member
    Yes I suppose I am heading in that direction. I'm 60 this year so it's a compromise between a Fireblade and a zimmer frame.
  6. Coda
    Coda Active Member
    According to @vic_ster51 that zimmer frame will take any blade engine from 08+:D
    • Funny Funny x 4
  7. Stuart Gould
    Stuart Gould Active Member
    Here you go, basically, two lines from the master using the longer bolt supplied (HEL Racing setup) then down the usual route, f/r line remade use of the pclip bracket then down to caliper. F/l went same route but reused pclip bracket on the mudguard.
    Sorry for my photography skills
    20220428_115617.jpg 20220428_115634.jpg 20220428_115640.jpg 20220428_115651.jpg 20220428_115658.jpg
  8. vic_ster51
    vic_ster51 Active Member
    If you referring to does any cbr1000rr engine 08-19 fit in a cb1000rr 08-19 frame and vice versa.
    Then it is does Fact!
    Could be a joke/you think you know better maybe? But don't knock other people's knowledge :)
  9. Coda
    Coda Active Member
    I think you misunderstand the joke.
    • Agree Agree x 4
  10. Coda
    Coda Active Member
    I just want to add, I have the greatest respect for your technical knowledge. If I wanted something for my bike and you gave me advice, I would trust you, no problem.
  11. Pete1987
    Pete1987 Active Member
    Nicely done everyone. I just got mine all bled the Brembo MC and M4s are a dramatic change to the old ABS Shite.
    Just need a new front tyre, MOT the. I am back on the road!
  12. CharlieR85
    I've heard tyres are getting more difficult to get hold of because of the Ukraine conflict, you'll have to let us know how you get on.
  13. Stuart Gould
    What does everyone do with all the ABS system they took off. Mines just sitting in a bag in the garage and I'm 2ondering if its worth anything to anyone? Obviously no one in this thread but would it be worth selling. Anyone still with abs and a failure could want a part like an module or pump? What do you reckon? Worth trying to sell?
  14. Coda
    Coda Active Member
    I dunno, if you had ABS and the pump failed, would you bother replacing the pump, or would you use the excuse to rip it all out? I think I'd do the latter.
  15. Stuart Gould
    Yeah, thats what I did but I wondered if some people might be adamant to keep their system in and therefore could save a lot on used parts? Might just list it and see if any takers and then dump it if not.
  16. Roman
    Roman New Member
    Hi guys. I have removed all ABS parts from my 2008 Fireblade followed by all wires. Conected the battery and tank back but when i press starting button nothing happens. Just silencDid anyone expected this too? Have checked all sockets and they are all connected. Also all fuses are ok. Any suggestions?
  17. Coda
    Coda Active Member
    Possible that kill switch needs a clean or maybe side stand switch or wiring has been cut?
  18. Roman
    Roman New Member
  19. Coda
    Coda Active Member
    Yes the two are not connected. The only thing you should see is the abs warning light on the dashboard should stay lit after you’ve passed 10km/h.
  20. Roman
    Roman New Member
    Well i foud suspicious socket which was connected to ABS wire system. One side with fuse goes to battery and the other goes to starter. The engine started when i connected plus from battery to connector from starter with additional cable. Any advice what now?
