2010... Numb bum
Discussion in 'General 1000RR Discussion' started by Patriotk11, Apr 29, 2022.
  1. Patriotk11
    Patriotk11 Active Member
    Hi
    I'm very new to the fireblade life but one thing I've noticed is ony 2010 model after riding 45 miles, my god do I have a numb bum.
    Anyone else have this issue
  2. Coda
    Coda Active Member
    At first I was thinking a similar thing, but I hadn't been on bikes for 17 years so I persevered, and now it's not a problem. Maybe you just need to get used to it? If not there are options.
  3. Boothman
    Get a secondhand eComfort seat and/or wear padded cycling shorts under your leathers.
  4. Patriotk11
    Maybe I am just delicate o_O :D
    I'd regret not asking but what are the options :):cool:
  5. Boothman
    What I mentioned above or go down the route of getting a trimmer to customise a seat with gel pads
  6. bladey
    bladey Senior Member
    Depends on your build too. That's more polite than asking if you're at one end of the spectrum or the other - rasher of wind or fat as my mother used to say :eek:. I often use the Forcefield shorts I bought for mountain biking under the leathers and they have some padding in the right places but I'm on my 6th Blade and I got used to the feel of the seat quite quick. If you can't then the suggestion of a comfort seat is your best plan. Depends on how long the longest trips you intend to go on. Mine are about an hour or so between stops so it's not much of a problem. YMMV.
  7. bonjo
    numbness can be causes by vibration / buzzing or poor circulation.
    if it is vibes, then try to find the reason for it mostlycaused by engine vibes.
    If you are skinny in the bum department, then extra padding will help.
    Poor circulation canbe either genetic or you posture on the bike. Experiment with repositioning yourself on the seat and putting more weight on the footpeg
  8. Patriotk11
    Lol I'm the skinnier end of the spectrum, and do about 100 miles a day, so riding can be 2.30 to 3 hrs a day. I don't thinky bum has time to recover so makes it more obvious lol.
    I think a comfort seat sounds the best option :rolleyes:
  9. bazzashadow
    bazzashadow Elite Member
    I get that after about 2 hours and probably 3 hours with an E seat
  10. Patriotk11
    There seems to be a lot of variations on the market, i don't want to buy the wrong one.
  11. bazzashadow
    Secondhand Honda E comfort seat will come up on here or flea bay
