2017 sp cut out ?
Discussion in 'Maintenance' started by keithg1748, Jul 12, 2022.
  1. keithg1748
    keithg1748 Active Member
    any ideas ? , went out on the bike everything seemed ok , until i set off in 1st gear hit 10 -11 k revs went up into 2nd then it just died and cut out , i managed to pull over off the road engine light was on , so i turned it off and on it started but would not respond to any throttle , turned it off and on again started it but went straight up to 4k revs so turned it off , anyway it did go back to normal but i turned round and limped it home , could it be summat to do with the battery ? , thanks for any info on this .
  2. Wes
    Wes Active Member
    I don’t think your battery would cause your start up rpm to somehow reach 4k.
    A vacuum leak or tps sensor ? Check for any leaks and do a quick voltage test on your sensor as preliminary checks. Voltage closed 0.5V open 4.5V.
    Best check those figures ! Best of luck mate
  3. keithg1748
    im guessing there a pig of a job ,
  4. Wes
    Wes Active Member
    Sensor requires multimeter. Not sure where your models located. But when you’re there it’s just a case of measuring the DC voltage. You tube probably help you out if your uncertain but definitely doable mate. If your in there with a meter now is the time to check the cmp sensor. This is the cam pulse sensor, another possible cause.
    Vacuum leak means a tank lift/removal for inspection of the area below.
    Possibly all sounds daunting, but we’ll worth having a go.
  5. keithg1748
    thanks , i will have a look on my day off work .
  6. keithg1748
    do any of thses make a bit of a noise from the front end when running ?
  7. Wes
    Wes Active Member
    Not really mate, a different tone would make me look at a vacuum leak.
    Has your bike had an exhaust mod done to it ?
  8. Wes
    Wes Active Member
    Not a different pipe but a mod
  9. keithg1748
    a full akra fitted .
  10. buz
    buz Active Member
    Put the display into mechanic mode and check the twist grip angle.
  11. keithg1748
    65 deg twist grip angle and battery voltage 13.1 .
