R/H Engine casing swap on 2018 sp.
Discussion in 'Maintenance' started by Edy, Aug 15, 2022.
  1. Edy
    Edy Active Member
    I need to change my r\h engine casing for a new one. I can carry out oil change, brake fluids etc myself but am unsure about the casing swap and cant find a tutorial. I have been told the clutch cable arm, on the casing, could be a bit of a pain to swap. Can anyone offer any guidance, please? Thanks.
  2. buz
    buz Active Member
    According to the manual, the lifter just pulls out.
    Turn it anticlockwise when pulling the side cover off. Reverse for installation.
    Apply silicone as below.
  3. Edy
    Edy Active Member
    Thankyou. I will get some sealant and give it a go. Hope it turns out as simple as it sounds.
  4. NS400R
    NS400R Elite Member
    Top tip, not silicone sealant. It isn’t oil resistant. Use a proper sealant as Honda advise for the job and use it very sparingly
  5. Edy
    Edy Active Member
  6. Edy
    Edy Active Member
    Ok, thanks.
