Brembo RCS19 brake master cylinder
Discussion in 'Parts, Accessories & Clothing' started by Muffking, Aug 15, 2022.
  1. Muffking
    Brembo RCS19 brake master cylinder and folding lever.
    Few minor scratches from loading up the bar straps.
    Used on my RR6 track bike for the last couple of years.
    Ideal if you want that firm brake lever feel.
    £150 delivered.
    Comes with the butterfly bracket to mount your existing brake reservoir, micro switch if fitting to a road bike and the original certificate of authenticity in the box.
  2. Muffking
    Now boxed up and ready to be sold.
    [​IMG][/url]
    [​IMG][/url]
  3. dern
    dern Well-Known Member
    Hi. I suspect that the answer is no but does this take a standard lever, or more specifically the twm levers that fit the standard master cylinder?
    Would I need anything else to fit this, I just have the standard setup at the moment but with two separate hoses from the matter to the callipers.
    Thanks
  4. Muffking
    Hi Mark.
    You don't need anything else if you already have the two brake line setup to the existing cylinder. Just fit the bolt with the 2 lines straight back into the new M/C and refit your existing brake reservoir.
    The standard Honda levers don't fit, but the Brembo fitting is a standard across all bikes.
