O2 sensor eliminator
Discussion in 'Mods, Upgrades, Accessories and Products' started by bonjo, Oct 21, 2022.
  1. bonjo
    I guess these do 2 things: keep the heater circuit functional (to avoid engine check light) and provide a fixed A/F mixture value to the ECU.
    The fixed A/F will no longer allow the ECU to change it. So my question for those who have fitted this is:
    Is it plug & play or plg and pray?
    Have you noticed and change in performance or mpg (good or bad)?
    PS road use only and with no engine tuning or power commander
  2. Slick
    Yep its plug and play, you will probably see a slight rise of MPG as the ECU wont lean out especially in constant throttle conditions.
    The bike will probably run smoother and be less snatchy
  3. buz
    buz Active Member
    What year is your bike? I don't think this works from 2017 due to anti tampering code in the ECU. You would need a Woolich reflash or Rapidbike Evo to defeat it.
  4. bonjo
    No mine is 2008 untouched by technology:) (only a little bit!)
    Well, slick's comment sound encouraging
    thanks
  5. Slick
    Not on my CBR but CB1000R, I removed the cat and deactivated the O2, ran it like that for about 6 months and it ran just fine.
    It was a slippery slope a mountain of mods though, ie full Dynojet back catalogue of PCV, Autotune, POD200 Leo Vince, pair delete etc etc etc!
  6. bonjo
    bad habits are hard to die:)
