cbr1000rr 20156 pop and bang
Discussion in 'Mods, Upgrades, Accessories and Products' started by Adriancbr, Dec 19, 2022.
  1. Adriancbr
    Adriancbr New Member
    Hi there i was wondering if any could point me in the right direction how to get alot of pop and bangs from the exhaust with flames i got exhaust installed from black widows also quick shifter was wondering what do i have to do and if i have to do a remap and if you know places anywhere in manchester i near or outskirts best regards,
    Adrian
  2. Broadie
    Broadie Active Member
    Fit some bigger valve shims
  3. Adriancbr
    anything else that would help ? with the bang and pops ?
  4. Adriancbr
    thanks 4 the reply io will trey look into something else first
  5. Jez
    Most now are closed loop fuel injection so need remapping
  6. Adriancbr
    you know anywhere good for a remap ? to go to and sort it ?
  7. Adriancbr
    also do i need a full exhaust kit with decat or just a canend changed ?
  8. Jez
    You need to decide exactly how you want your bike, exhaust etc then fit them, and then get it set up, remaps aren't cheap so you need to have the bike as you want it before taking it, I don't know of any one that would do it
  9. CharlieR85
    Not my cup of tea but I'd imagine the first step in whatever route you take will be to get rid of the cat by fitting aftermarket headers. The stock headers keep the noise down a lot.
    The headers on their own may give you what you want I don't know.
    The nuclear option is to fit your headers then a power commander and get someone to write you a custom map. If a performance orientated map still doesn't give you what you want then you could fit a map switch and get the tuner to write you 2 maps....first would be the performance map and then "just for fun" a 2nd map that gives you pops and bangs.
    Headers, power commander and a custom map is going to cost you a fair bit.
  10. bonjo
    to me sounds like the engine is either running too rich or the fuel is not burnt properly. You get unburnt fuel in the exhaust whihc pops, bangs and flashes when the ECU sends air to burn it off.
    If you have removed the O2 sensor, then this could be the reason.
    As an aside I have read people hearing more pops when they change for a louder silencer
  11. CharlieR85
    I think he wants to achieve pops, bangs and flames not get rid of them.
  12. raphael
    The flames will be from un burnt fuel on over run, if you still have the cat the system there’s a chance it will melt if you can get anyone to map it to pop and bang.
    Sounds like you want a map like the cars? In reality, any place that will say they can map it like that for you isn’t really worth going to as it really defeats the object of mapping a bike as won’t be running to its optimum
    • Agree Agree x 4
  13. Jez
    I am not 100% sure but I think the pair valve is there to help burn unburned fuel as it enters the exhaust, a lot of people blank these off
  14. CharlieR85
    Yep spot on, mine are blanked off though and it didn't make any difference to the exhaust sound popping or otherwise.
    On the BMW S1000's they pop a little bit but only when in dynamic mode, I think this is achieved via some sort of valve in the exhaust that allows more air in.
