Camchain tension release tool
Discussion in 'Maintenance' started by NS400R, Jan 26, 2023.
  1. NS400R
    NS400R Elite Member
    Handy little tool, but bloody expensive for what it is. Cheaper than ripping the thread out the block removing the tensioner or damaging the Cam chain though..…. Most just use a screwdriver.
    3D34C344-F478-4B31-934B-09503BDF98DE.jpeg 2CC8A624-0243-487A-BABD-E2E8E1C01010.jpeg
  2. PARADOC
    PARADOC New Member
    how much was that cam chain tool
  3. NS400R
    NS400R Elite Member
    You don’t want to know :eek:
    Retail is around £260…..
  4. Coda
    Coda Active Member
    Wtf. And people thought Ducati tools were overpriced. :D
  5. Lozzy
    Wtf :eek:
  6. NS400R
    NS400R Elite Member
    But cheaper than cocking about with a screwdriver and damaging something…. Compared to the cost of getting clearances checked by a garage, small beer…. I paid £200. But realistically someone with a small lathe could knock one together…
  7. TonyEmm
    TonyEmm Member
    Let me start by saying I love buying tools. My whole life my mantra has been I would rather buy the tool once and teach myself how to do a thing than pay someone else to do it for me. Obviously there are exceptions to this, my recent appendicitis experience for example.
    However, I was gobsmacked at the front of Honda charging so much for this tool, when it’s not necessary. Don’t get me wrong, if you’re a tech at a main dealer and you’re doing several bikes a week then fair play, but to the average joe that might use this once in a blue moon?
    Make this out of scrap metal, it works. Btw, If you buy a new cct from Yamaha it comes with something similar preinstalled, not sure about Honda.
  8. Coda
    Coda Active Member
    With the state of the NHS I’m fully prepared to learn how to remove my own appendix.
    • Funny Funny x 4
  9. NS400R
    NS400R Elite Member
    Agreed. Must admit I was expecting a tad more. But it has saved me money so I’ll swallow it
  10. TonyEmm
    TonyEmm Member
    I was thinking twice about posting my comment to be honest as it’s easy for these things to be misconstrued, but it’s squarely aimed at future readers to save them the expense if they can’t, or don’t want to, spend the money on the factory tool.
    As I said, like you, I have often absorbed the cost of factory workshop tools using the infallible man maths.
    It certainly applies to valve clearances, what does that cost nowadays? £500 minimum, I’m guessing? Then you can’t even be certain they’ve even lifted the cover let alone checked anything. Hence why I’ve taught myself, and more power to your elbow for tackling it yourself as well.
    Your comment got me thinking, perhaps I should buy a lathe next……
  11. NS400R
    NS400R Elite Member
    ‘Twas exactly that thinking. No offence taken! It is partly why I posted to make others think before buying. I was surprised no-one makes an aftermarket one
  12. B626
    B626 New Member
    When I did the valve clearances I fashioned one of these tools from an old pci-e blanking plate from a computer (essentially 1mm thick Ali). Just about did the job but did bend a bit more than I would have liked.
    Made me wonder whether a 3d printed version would be strong enough...
  13. PARADOC
    PARADOC New Member
    DAMN THATS A TAD EXPENSIVE,I THOUGHT BMW TOOLS WERE DEAR,THE CHINESE WILL PROB MAKE ONE SOON ENOUGH
  14. dern
    dern Well-Known Member
    I made one of those tools from aluminium that was kicking about in the garage but yours is a lot nicer. Worked fine for years until I predictably lost it.
  15. CharlieR85
    When are you doing your valve clearances @NS400R ?
  16. NS400R
    NS400R Elite Member
    Done them. Just putting it back together now
    #16 NS400R, Jan 31, 2023
  17. CharlieR85
    I've knocked one up on the mini lathe. Copied the copy though.
  18. NS400R
    NS400R Elite Member
    Well done. My disadvantage was that without seeing it in the flesh, it wasn’t immediately apparent what the advantage was/is. Bear in mind I’m an accountant not a mechanic. Hopefully this thread will help others. The only benefits from my side are that it was cheaper than getting it done professionally and I’ve now got the tool to sort my CBF1000 and my son’s VFR. Plus I like to think the debate on here has been helpful to others. Should’ve stuck to 2 strokes. Much simpler :cool:
  19. CharlieR85
    You can't regret getting the Honda one mate, it will work perfectly for you forever. I fully anticipate having to remake mine a few times until its right.
  20. NS400R
    NS400R Elite Member
    Can send you some dimensions if you want.
