Gear indicator for '08
Discussion in 'Mods, Upgrades, Accessories and Products' started by AbuJane, Mar 2, 2023.
  1. AbuJane
    AbuJane New Member
    WhatsApp Image 2023-02-28 at 15.39.06.jpeg HI everyone,
    Bike arrives tomorrow and while reading through the owners manual (yeah i did that as i'm laid up in bed due to an injury) i realised that there is no gear indicator.
    Any recommendations on an after market (hopefully plug and play) one?
    Thanks as ever
  2. Coda
    Coda Active Member
    There are plenty on eBay, usually a single LED matrix type, quite cheap and they’re all copies of the same thing so get the cheapest one.
  3. AbuJane
    AbuJane New Member
    I guessed that might have been the case Coda, but thanks for the confirmation.
    Will wait and see if any 'spare' plugs when bike arrives tomorrow then get one ordered
  4. Coda
    Coda Active Member
    I don’t think they go on spare plugs, but rather you disconnect the gear shift sensor and plug the unit between it, like you do with speedo healers and quickshifters. At least that’s what I think you do.
  5. AbuJane
    AbuJane New Member
    I'll have a look when the bike arrives. Some of the more expensive (circa £100) are true plug and play but i think most require a bit of fettling or fitting of a new plug
  6. Jez
    The one I bought for my R1 from memory had 12v and then connected to the speedo and tacho, you then have to calibrate it, It was relatively easy other than finding the wires
  7. warren smart
    warren smart Active Member
    #7 warren smart, Mar 8, 2023
  8. Coda
    Coda Active Member
