Clip ons and rear set recommendations please
Discussion in 'Mods, Upgrades, Accessories and Products' started by dern, Mar 12, 2023.
  1. dern
    dern Well-Known Member
    Can anyone recommend clip ons and rear sets for a cbr1000rr 2007 please. It’s not for road use. I don’t need the best but I don’t want to inadvertently fit garbage. Thanks.
  2. Cookster
    Cookster Active Member
    Renthal clip ons are good, try and find some light tech rear sets.
  3. warren smart
    warren smart Active Member
    I have a couple sets of robbymoto clipons, very good quality and you can get different heights.
  4. Muffking
    Are you just looking to change the angle Mark, or are you looking for something a bit trick?
    Did I tell you about grinding off the locating pin on the original bars? I've done exactly the same to the BMW too.
  5. dern
    You did tell me about that but I must admit that I'd forgotten, d'oh. I'll do that first, thanks.
  6. warren smart
    Depending on the angle of the oe bars if you put the left on the right and right on the left upside down they can come out a flatter profile.
  7. Muffking
    lol, no worries.
    If you undo the bolts where the bars clamp onto each fork then you can slide them down the fork leg and get a Dremel drill (or similar) in to cut the locating lugs off. There's enough room to get a cutting tool in without having to remove the bars. I managed to get one of these in as the clamp is only made of aluminium.
