2020 RRR
Discussion in 'Forum Announcements' started by russblade1, Mar 30, 2023.
  1. russblade1
    russblade1 Active Member
    bolt and nut Torque settings eg Sprocket etc where can I find them please?
  2. russblade1
    Also has anyone tried one of these-S-H10SO25-APLT/TD - Exhaust Muffler Akrapovic Track Day Honda CBR 1000RR ?
    I'm need to reduce noise level to go on Track ? tia
  3. Coda
    Coda Active Member
    I think forum announcements are the wrong place for these posts.
  4. russblade1
    Yes well spotted where’d they go then and how do get there
  5. dgr
    dgr Active Member
    The workshop service manual is the only place, as far as I am aware.
  6. Jay Floyd
    Jay Floyd Active Member
    Rear Sprocket 63 Nm
    Front Sprocket 54 Nm
    Oil Filter 26 Nm
    Sump Bolt 30 Nm
    Fork Pinch Bolts 22 Nm
    Caliper Bolts 40 Nm
    Front Spindle 79 Nm
    Rear Axle 135 Nm
    Hope this helps buddy.:)
    • Useful Useful x 2
  7. russblade1
    yes thanks jay, now trying for an hour put rear wheel on, why is it so fkn difficult? is there an easy way???
  8. Coda
    Coda Active Member
    Not sure about the 20 model but the first time I tried putting the rear back on on my ‘14 it was a pain.
    In my case, Caliper bracket goes on the hub first, offer up the wheel, put the chain on the sprocket, push the axle in a little way, then as you push the wheel up and in, slide the caliper arm into the slot in the swingarm.
  9. Ritchierich
    Ritchierich Elite Member
