2008 bike not starting FFS
Discussion in 'Maintenance' started by AbuJane, Apr 4, 2023.
  1. AbuJane
    AbuJane New Member
    HI guys,
    I have looked through the first 12 pages on this part of the from to see if this topic was covered, and yeah i see the comments below on the much newer bike.
    I hired a mechanic mate to come round on Sunday to give me a hand setting up the bike (i insisted on paying for his time). we did the chain then checked all the suspension heights and a couple of other little jobs while drinking tea and eating bacon sandwiches. Mega time - then i went to start the bike after it had been on Li ion optimal charger/maintainer for a few days. It primed and turned over but would not catch. kept trying with the new Li ion battery then put a jump pack on it, wouldn't start. then connected a spare 300CCA gel battery that i have in the garage, wouldn't start. My mate got tore into the bike, had 3 of the plus out and checked them, they wet but otherwise fine - maybe wet due to us trying repeatedly to start the bike...
    As a few of you will recognise my profile name i am new to this bike and Fireblades so any advice or guidance or "well everyone knows x" would be welcomed.
    The bike ships to Almeria on 15th for 5 days of riding at the end of April.
    Please help! Are there things i should be trying, as ever, thanks in advance guys.
    #1 AbuJane, Apr 4, 2023
  2. Boothman
    Did you see a spark at the plugs you took out?
  3. AbuJane
    AbuJane New Member
    Hey Boothman,
    No we didn't see spark as my mate said we couldn't do that as everything was unplugged/removed to get to the plugs IMG_6289 2.jpg
  4. Wes
    Wes Active Member
    Need a little more information to get this resolved really.
    For instance, prior to your bacon roll n tea was she running well or had recently had any issue at all ?
  5. AbuJane
    AbuJane New Member
    Hey Wes, i've had the bikes for a few weeks and it has never started well from 'cold' once its started it will restart pretty much first press even if left for an hour or so (so i am guessing still warm).
    We had not started the bike at all as the jobs that we wanted to do did not require the bike to be started - suspension and chain. It was only when went to start the bike that we realised it just wouldn't start. Gary (mech) could hear primer working, and it did turn over, nearly caught once but just didn't.
  6. Boothman
    How old is the fuel or have you recently filled up? If it’s been stood a while it could have separated and drawn water in. Alternatively if you’ve not long since filled up I remember @PauloHRC had his Ducati in the shop for a while (wouldn’t start) and turned out to be shite fuel.
  7. PauloHRC
    Yep, the dreaded e10 !! Dont use it unless you empty your tank after every ride!!!o_O
    No pun intended :D
  8. bladey
    bladey Senior Member
    As for fuel I've been using Jet Ultra up to recently as the garage is close by, it's advertised as E5 so I thought it would be average. Started to go back to the Esso dealer for the last few fill ups of their 99octane and the difference is chalk and cheese. Better all round, 25p litre more worth it to me.
    • Agree Agree x 3
  9. AbuJane
    AbuJane New Member
    Fuel is about a week old mate, bike was dry when i received it so there can be no fuel in there that is older than 4 weeks
  10. AbuJane
    AbuJane New Member
    Thanks Bladey, i will chose the higher octane going forward
  11. AbuJane
    AbuJane New Member
    Here is a quick video of the bike not starting in case this helps...
    i gave the air intakes a squirt of carb cleaner but not sure how much i should use so just gave a couple of quick squirts
  12. Selmer50mark
    Sounds like the starter is not engaging properly, does it wind the engine over ok with the kill switch off.
  13. DrMashiro2
    DrMashiro2 Active Member
    Can you bump start it?
    If it starts with a rolling bump you can rule out spark plugs etc. It would then be narrowed down to starter motor.
    Did you check for a faulty side stand switch? Lean over switch?
  14. blink
    blink Well-Known Member
    that reminds me, my kill switch sticks sometimes, even in the fully on position, so it cranks but doesnt catch,
  15. AbuJane
    AbuJane New Member
    Anybody know if replacing the sprag gear requires an engine split?
    There is only one mention of Sprag gear in any of the forums
  16. Broadie
    Broadie Active Member
    Starter gears are in the clutch casing. Has anyone been in there recently ie new clutch ect?
    #16 Broadie, Apr 10, 2023
  17. AbuJane
    AbuJane New Member
    Racing Technician came out last night, listened to the bike and thought that it might be sprag gear. Stripped right hand engine panel off and checked the sprag gear but it seemed to be working fine. Therefore or QED if you wish, it must be a starter motor issue. Going to strip out my starter motor today and then steal one from a friend's bike! Install into mine and see if that works. If it does then i can borrow it for the duration of my trip to Spain and then fit a new one on return...i'll keep you posted!
    • Optimistic Optimistic x 1
  18. Jez
    Agree, it does sound like a starter motor issue
    • Disagree Disagree x 1
  19. AbuJane
    AbuJane New Member
    Stripped out starter motor, drove like a demon to mates house about 45 minutes away. Removed his starter, drove home (also demonesque) and fitted his. Bike still wouldn't start, no real change in noise/sounds/actions from bike. Removed his starter, re-fitted mine. Yeah no change. Went inside and ordered a sprag clutch starter gear and 24-hour postage from ebay. That arrives tomorrow (Friday) bike has to be ready to take down the road at 05:00 on Saturday. What a mare
  20. AbuJane
    AbuJane New Member
    sadly it wasn't jez
