Charging & Using Lithium Ion Motorcycle Batteries
Discussion in 'Mods, Upgrades, Accessories and Products' started by BladeRR8, Feb 22, 2012.
  1. BladeRR8
    BladeRR8 Active Member
    I m thinking of buying a Lithium Ion battery for my bike to save a few kilos.
    I don't use the bike during the winter so always use a trickle charger and I m a little confused if these can be used on Lithium Ion batteries as have found 2 differing opinions on the subject.
    This is what Ultrabatt say
    In an "emergency" you could use a trickle charger for about 10-15 minutes, BUT... a trickle charger can kill every lithium battery same like a lithium charger can kill a lead-acid battery. Different technologies and different chemical reactions makes them also require having different charging amps/voltages and charging characteristics. Our lithium batteries can be used and charged by your motorcycle itself, but only don't use a trickle charger.
    This is what Racing Batteries say
    Using a Racing Battery on the road requires a little extra care as they don't carry the excess Amp Hours that a Lead Acid unit does. The main problem is alarms and other stray current drains - Racing Batteries don't like being drained absolutely flat and being left in the garage in a discharged state. But as long as you get your optimate attached within a week or so of putting her away you'll be fine (or bettery still isolate the battery when not in use). Likewise, you'll damage the battery if you leave the headlights on and the engine off for more than 10 minutes or so.
  2. Sulby140
    Sulby140 Active Member
    BladeRR8, if you're going the route of a Lithium battery then it uses a different charger, normal charger is constant current gradually reducing as the internal resistance rises with charge state, Lithium chargers are constant voltage and suitable ones are available, I assume you're looking at a Lithium Iron Phosphate type battery as it overcomes the safety implications of other types, wouldn't think any other would be suitable for bike applications, plenty of info on Wikipedia if you're interested.......Mike
  3. BlackDevil
    Some Info's you should read before you buy.
    Shorai Motorcycle Battery vs. Ballistic Motorcycle Battery Comparison - webBikeWorld
    Shorai LFX14A1-BS12 Battery - £129.95
    Ballistic Battery 12V LiFePO4 8 Cell EVO 2
    Vehicle Replacement Batteries for Motorcycles, ATV, Watercraft, Snowmobile, Utility Vehicle
    Ballistic Battery 12V LiFePO4 EVO 2 Review - YouTube
    Ballistic Battery EVO2 Review at Motochanic.com - YouTube
    Shorai Lightweight Motorcycle Battery Review - Make your motorcycle 4 pounds lighter. - YouTube
  4. Remal
    Also intrested I these battery's. And some great info on here already
  5. BladeRR8
    Cheers for all the replies and some great info BlackDevil really appreciated mate, Thanks !!!!!!!!
    Been doing some more research today and although I m really interested in one of these I was put off a little when I read their not recommended if you have an alarm fitted as I think they drain them to quickly and if they go flat thery are totally unrecoverable which does'nt sound good.
  6. JM1
    JM1 Active Member
    I'm using a Skyrich Li-Ion (£165) and it seeems fine. I think this is silghtly different from a Li Iron Phosphate battery?
    Optimate 4 doesn't seem to work with it (I just tried it myself as was getting mixed messages about trickle chargers).
    Anyone got a specific link to a specialised charger for these batteries?
  7. BladeRR8
  8. BlackDevil
  9. JM1
    JM1 Active Member
    No alarm fitted. I've left it for up to 3 weeks and it start fine.
  10. BladeRR8
    Cheers JM1 just need to get rid of my alarm now as its a datatool s3 and is just a pain in the backside but unfortunately its required by the insurance company so preferable if I could disarm long term whilst in storage in the garage.
  11. JM1
    JM1 Active Member
    Thanks for the charger links!
  12. JM1
    JM1 Active Member
    I forgot to mention that when I asked Skyrich how to charge it they said treat it exactly as you would a lead acid battery. Confusing!
  13. BladeRR8
    Very confusing I agree.
    I believe you can use a trickle charger if it has'nt got a desfulate mode or something but not 100% sure, hopefully some one will be along soon and correct me.
  14. JM1
    JM1 Active Member
    Yeah I heard that too, but not sure how to establish whether Optimate 4 (for example) has a desulphate mode.
  15. JM1
    JM1 Active Member
