Battery issue
Discussion in 'Maintenance' started by Swadnod, Jun 15, 2023.
  1. Swadnod
    Swadnod New Member
    Guys , my 21 blade RRR-sp has got battery issues , twice I've had to charge the battery, as I've gone to start the bike and I've nothing on the dash, yet the bikes used regularly, anybody else had this issue before.
  2. Boothman
    Do you keep it on a trickle charger? Does it have a tracker/alarm?
  3. Swadnod
    Swadnod New Member
    It doesn't have an alarm / tracker fitted buddy , but, yes ,I do occasionally put it on trickle charge.
  4. Saqib
    Saqib Active Member
    Best to get a voltmeter.
    You should see 12.4V with engine off, and 13.5-14.0 V with engine running (or holding revs a little above idle).
    If you see less than 12.4V with engine off, then likely you have a duff battery. If you don't see the right voltage with engine running, then its a charging issue.
    If both are okay, they you could have a duff cell in the battery.
    Hope that helps!
  5. Swadnod
    Swadnod New Member
    Cheers bro, this is helpful
  6. Broadie
    Broadie Active Member
    Datatool will drain a battery in 4days if not on charge or riding.
  7. BooMTowN
    BooMTowN Member
    Datatool tracker draining my s1000rr every few days when not used...
  8. bonjo
    doesn't 21 model come with LFP battery? If so, the voltage shoul stay above 13.3v even after 2 weeks of non use. Because of their low capacity, they drain very quickly.
    If it is AGM, then 12.8 for reliable starting winter or summer.
    your charging voltage with the bike running@ 5k should be around 14.4v, less than 15v
  9. Swadnod
    Swadnod New Member
    Hi buddy , yes it's a LFP battery, I get the feeling I'm leaving the ignition on somehow and going back to the bike 20 mins later and it's dead, think it's pilot error.
  10. dgr
    dgr Active Member
    The RR-R has a voltmeter built in to the dash. You can choose to display it as one of the pieces of information on the standard layout.
  11. dgr
    dgr Active Member
    Twist the outer ring on the starter button to turn the bike off. When off, turn and hold to engage the steering lock. Never use the kill switch to turn the engine off, unless it is an emergency.
  12. Swadnod
    Swadnod New Member
    I think this might be where I'm going wrong, I've only used the kill switch thus far, didn't even know you could turn it off any other way , doh
    Appreciate the heads up
  13. steve750
    steve750 Active Member
    Are you based in Swadlincote Swadnod?
  14. Swadnod
    Swadnod New Member
    Yes buddy , I'm in the posh part
    Newhall.
  15. steve750
    Wicked mate....me too!!
    • Friendly Friendly x 1
  16. BooMTowN
    BooMTowN Member
    I called into bmw last week,they said they stopped using datatool because of this vert reason...causing lots and lots of problems...they suggested ripping it out free of charge,but I'm might just buy an optimiser that fits...
