2017-2019 CBR1000RR left handle switch hub needed in Turkey.
Discussion in 'Mods, Upgrades, Accessories and Products' started by AhmedAlogaili, Jul 14, 2023.
  1. AhmedAlogaili
    AhmedAlogaili Member
    Hello eveyone, I'd like to know if I could find a cheap and functional left side handle switch assembly for my 2018 SC77. I have all buttons working except LAP and HAZARD buttons.
    My main goal is to get everything working and looking well for cheap.
    FRONT facing part with LAP / HAZARD buttons is required if possible.
  2. Boothman
    @vic_ster51
  3. AhmedAlogaili
    Problem solved, last night I went down to inspect the switch hub furthermore to see the actual damage. What I found is that the LAP switch housing was shattered into 4 pieces and some of the pieces were blocking the movement of hazard light switch. After some further disassembly and some ABS welding with the iron solider using my ABS car bumper repair strips (didn’t have glue at 12am) I was able to bring the LAP switch into one piece. I reinstalled everything and bang! Everything is back to its functional state. I will try to sand the outer side to get a more uniform aesthetic look later.
    #3 AhmedAlogaili, Jul 15, 2023
