Healtech AR Assistant (and other traction/wheelie/launch control systems)
Discussion in 'Mods, Upgrades, Accessories and Products' started by jokeshopbeard, May 8, 2021.
  1. Kake
    Kake Active Member
    No because it's a race bike so to ride 60km/h is virtually impossible.
  2. shahwales
    shahwales Active Member
    Will be difficult if not using the wizard. Healtech may be able to help. But to do 60km/h on the pit lane is easy enough and you can use a phone strapped to the tank as a speedo
  3. Kake
    Kake Active Member
    We got a permit to ride 1 slow lap
    using the wizard and now it seems to be working. We're still not getting the rpm on Ilogger easy dashboard .
  4. Kake
    Kake Active Member
    Ok friends, a quick update. As previously mentioned we got it working (ARa). So far we're in the early stages of testing it but the initial feeling about it positive. So far he's tested it down to level 4. My fear was that the wheelie control would be too intrusive but it seems that it's not. Obviously testing continues but so far my son has been really happy with it. We've combined it with together with the Ilogger easy and he made it so that he can change the ARa map with handle bar push buttons. So far we've had 2 gripes with the system, 1, we can't seem to do the manual settings for ARa , 2 you need to have the phone with you in order to be able to use the push buttons on the handle bar. More info will follow after next test session.
    #24 Kake, Jul 21, 2023
  5. Kake
    Kake Active Member
    Ok , another test done on different track. My son was using settings 1,2 and 3 this time on dry track. According to him the WC is cutting power a bit too much. On setting 1 he was happier with the WC but the TC wasn't really doing anything anymore. He was the happiest on level 2 but like said the WC was just a hint too intrusive according to him. The other issue is that the dashboard function of still not working on the I logger easy. Now we got laptimes and graphics out but no dashboard as of yet. Keep you posted.
  6. DrMashiro2
    DrMashiro2 Active Member
    Thanks so much for the information. Please keep it coming. I'm very tempted to buy the TC.
