CBR1000RR 04 - 07 Full BAZZAZ TRaction Control with Fuel and Quickshifter
Discussion in 'Parts, Accessories & Clothing' started by brg1000, Mar 16, 2018.
  1. brg1000
    brg1000 Active Member
    This is the top of the range system for the 04-07 Fireblade.
    It features Traction Control.
    All 8 injector fuel control
    Universal Strain Shifter - does both push and pull.
    The kit is complete and I can load a good fuel map for your bike. It fuels all 8 injectors and will give you very close to perfect fuelling. With a full system you can expect 10 - 15 extra BHP over and above what you are getting. The unit will come with the correct o2 sensor eliminator for the 06/07 bike. The 04/05 doesnt use one.
    The Traction Control is a software based program and while it is a basic TC it is very effective. If you feel its coming on when you dont want it simply turn the TC down. It is a great system.
    The quickshifter is a strain shifter which operates push or pull. Its not an auto blipper so you cant change 6 - 5 - 4 etc just 1 - 2 - 3 - 4 - 5 - 6. The shifter can be mapped for each gear and the sensitivity is a dream. The shifter is brilliant. As good as any on the market. Up there with the HM Plus SS easily.
    I have the automapper available which allows you to build your fuel map while you ride. I can see it or lend it out against deposit.
    I also have the optional TC active light which illuminates blue when the TC is active and I have the combined MAP select and TC switch. This allows you to switch between maps and adjust the TC on the fly.
    It is a great system and works very well. You can turn the TC off if you wish and if you are racing beware that most classes do NOT allow this system to be fitted. If you are a track day man or girl this is perfect for you.
    New these systems cost nearly £600. I am looking for £350 for the TC system. £50 for the TC/Map switch. £25 for the TC active light and £125 for the Automapper. I would take a bit less for the lot.
    Barry 07921 849 076
  2. nigelrb
    And who just bought an '04?
    Sorry, Barry. Keeping this one original. You're offering an excellent pickup for someone though!! Cheers!
  3. Tezza H
    Tezza H Active Member
    Hey Barry, ill have the TC / map controller and the TC light off you, Cheers
  4. Tezza H
    Payment sent :):)
  5. Sc57 king
    Sc57 king New Member
    Do you have a picture with the TC map or remember it? Alao what kill times did you use for the QS?
  6. Broadie
    Broadie Active Member
    Just out of interest! Is this a piggy back system or does it replace the ECU?
  7. Sc57 king
    It s a piggy back. Zi fi tc
  8. Royde84
    Royde84 New Member
    Hiya,
    Is any of these items still available?
    Cheers, Roy
