Head stock paddock stand
Discussion in 'Maintenance' started by jivinjas, Dec 2, 2023.
  1. jivinjas
    jivinjas New Member
    Hi all just brought one of these and the biggest pin is size 18 but it’s like very loose and wobbly. Do any of you guys use these stands and what size pins do you have? It’s a 2015 bike. Thanks
  2. Muffking
    Yep. Find a bit of tube to sleeve one of the pins to a bigger size. I can't remember the exact size, but someone will likely post what size it is.
  3. Surfinbill
    Surfinbill New Member
    Like @Muffking says , and here's a list to help you on
  4. jivinjas
    jivinjas New Member
    That’s great. Many thanks
  5. bazzashadow
    bazzashadow Elite Member
    My mate machined me one up but I can’t remember the size 22mm I think
  6. bazzashadow
    There you go
    Just been out in a freezing cold shed:D:D 23mm
  7. jivinjas
    jivinjas New Member
    Mate. You are a star. Many thanks
    • Friendly Friendly x 1
  8. bazzashadow
    Mine is a 16 so same headstock
  9. jivinjas
    jivinjas New Member
    I’ve just looked to buy a 23mm but can’t see one anywhere. So just ordered a 24mm and if needed I will shave a bit off
  10. jivinjas
    jivinjas New Member
    Just a heads up. I ordered a 24mm and had to shave 1 mm off. So now sorted. Funny thing is looking for a 23mm is like looking for hens teeth. No where to be seen.
  11. bazzashadow
    Did you try the 24mm to see if it fitted
  12. jivinjas
    jivinjas New Member
    Yes it was too tight to fit
  13. Shrappers
    Shrappers Active Member
    If anyone is buying one for their SP, double check as mine is 27mm. I think the SP is bigger for some reason.
  14. jivinjas
    jivinjas New Member
    That’s strange I would have thought they would be the same. What year is your SP?
  15. Shrappers
    2016. Yeah I thought it was odd. When you look at the list provided further back the SP is a different number as well.
  16. jivinjas
    jivinjas New Member
    Learn something new every day. So obviously that must be modified for the SP. I never knew that.
  17. TheGodfather
    TheGodfather Member
    Mines a 22 SP and I've ordered the 24mm. Will have to get the grinder on it when it arrives.
  18. jivinjas
    jivinjas New Member
    Don’t shave much off. I literally rubbed mine on sand paper
  19. Broadie
    Broadie Active Member
    I just used a ⅜ deep reach socket over one of the smaller fittings.
  20. jivinjas
    jivinjas New Member
    Now that’s thinking outside the box. Nice idea or it works it works
