Reconnected battery and no power
Discussion in 'General 1000RR Discussion' started by Alan Summers, Apr 6, 2024.
  1. Alan Summers
    Alan Summers Active Member
    Literally disconnected the negative terminal and reconnected after about 5 seconds and no power at all, am I missing something?
  2. Selmer50mark
    Main fuse?
  3. Alan Summers
    Where is that Mark do you know?
  4. Selmer50mark
    Not sure on your model, probably next to the battery
  5. Boothman
  6. Alan Summers
    Going to have another look tomorrow
  7. Broadie
    Broadie Active Member
    Try disconnecting for 30 minutes whilst you check the fuses at fuse box and beside starter relay.
  8. Alan Summers
    Sorted, I had left a connection under the tank unclipped. Thanks guys for the responses.
    • Like Like x 6
  9. Selmer50mark
    :rolleyes: easily done , at least it's nothing serious ;)
  10. PauloHRC
    Why did you do it in the first place?
    #10 PauloHRC, Apr 7, 2024
  11. Alan Summers
    Took an earth connection away from the battery.
